Mitsubishi Outlander DCDC OBC
Revision as of 21:29, 5 May 2023 by Crasbe (talk | contribs) (Changed pre-blocks to syntaxhighlight-blocks)
* Length 370mm
* Width 270mm
* Height 150mm
DC-DC Converter
*at about 397v the dcdc appears to stop operating via the enable lines. currently untested if it continues via can. [3]
Signal Connector
Pinout for the Signal Connector [1][2][3][4][5]
Pin on 13-pin Connector Pin on Internal Connector Color Color from Schematic Name Function
1 Orange NC Not Connected
2 NC Not Connected
3 Blue NC Not Connected
4 Violet-Green DC SW Enable DC/DC Converter
5 Pink-Green CHIN Serial Protocol to EV Remote WiFi Module
6 Black Black-Blue CAN H CAN High
7 Grey Sense Sense for DC/DC Converter (via shared 7.5A fuse)
8 Light Green IGCT Main +12V Power Supply (via shared 7.5A fuse)
9 Blue CP Control Pilot from Charge Port
10 Black GND Ground
11 NC Not Connected
12 Brown-Red / Yellow-Black CHOT Serial Protocol to EV Remote WiFi Module
13 Red Red-Blue CAN L CAN Low
Note: Although the above pin numbers match the Mitsubishi wiring diagram the numbers marked on the connectors are reversed for each row. Pin 1 is CAN H (Black), pin 6 is NC (orange), pin 7 is CAN L (red ) and pin 13 Sense ( green ).
AC Power Connector
The AC power connector is Yazaki 7283-7350-30 / Toyota 90980-11413. https://www.auto-click.co.uk/7283-7350-30?search=90980-11413
+12V DC Connector
The thread size of the +12V stud of the DC/DC converter is M8.
Charge Control
CANBus Messages
Outlander Charger DBC File
0x286 byte 2 sets the DC charge current, there is a voltage setting on byte 0 and 1. The charger reads this value only once. To update it, you have to first power cycle the 12V line "Pin 8 IGCT main power to charger". The requested current should be limited to 12A, going above this results in strange current delivery.
- Byte 0-1 = Voltage setpoint (Big Endian e.g. 0x0E 0x74 = 3700 = 370v)
- B5 = Temperature 2		(starts at -40degC, +1degC/bit)
- B6 = Temperature 3		(starts at -40degC, +1degC/bit)
- B7 = Statusbyte 		(h20=standby, h21=error, h22=in operation)
-  - bit0(LSB) = Error
-  - bit1	= In Operation
-  - bit3      =
-  - bit4      =
-  - bit5      = Ready
-  - bit6	=
-  - bit7(MSB) =
0x389
- B6 = Charger Supply Current x 10
0x38A
- B0 = temp x 2?
- B1 = temp x 2?
Parallel charger control:
Charger voltage control:
CAN_FRAME incoming;
if (Can0.available() > 0) {
    Can0.read(incoming);
    if (incoming.id == 0x389) {
        voltage = incoming.data.bytes[0];
        Ctemp = incoming.data.bytes[4];
    if (incoming.id == 0x377){
        aux1 = incoming.data.bytes[0];
        aux2 = incoming.data.bytes[1];
        auxvoltage = ((aux1 * 256) + aux2); //recalculate two bit voltage value
void sendCANframeA() {
	outframe.id = 0x286; // Set our transmission address ID
	outframe.rtr=1; //No request
	outframe.data.bytes[0]=0x28;
	if(voltage < 193) { // if Charger senses less than 386V
		outframe.data.bytes[2]=0x1E;
	else {  //any other case
		outframe.data.bytes[2]=0x00;
	outframe.data.bytes[4]=0x00;
	outframe.data.bytes[5]=0x00;
	outframe.data.bytes[6]=0x0A;
	outframe.data.bytes[7]=0x00;
DCDC aux voltage control
if (auxvoltage < 1200) { // if aux voltage is low and DCDC is off
    auxState = true; // set the flag to true
    elapsedtime = millis();
DCDCauxcharge();
void DCDCauxcharge() {
    if ((auxState == true) && (digitalRead(Enable_pin) == LOW)) { // auxvoltage went below 12.2V
        digitalWrite(DCDC_active, HIGH);
        if (millis() - elapsedtime >= ontime) { // if aux voltage is low and for 5min
            auxState = false;
    else { // if auxvoltage is OK
        auxState = false; // turn off DCDC_active relay
