Mitsubishi Outlander DCDC OBC
- 3.3kw charger
- 1.8kw DCDC converter
- canbus controlled
Found in:
- i-MiEV
- Outlander PHEV
- Minicab MiEV
Units out of the Outlander PHEV are most common and can be bought for under $100.
*The old 3.7kW versions from the i-MiEV (pre 2013) are known to fail often and need repair.
*Outlander units are tested and work with the zombieverter vcu.
Latest versions from the Outlander seem to have V2L capabilities[1].
Part numbers from the Outlander PHEV:
Forum thread: https://openinverter.org/forum/viewtopic.php?t=628
* Length 370mm * Width 270mm * Height 150mm * Weight 12.5kg (W005T70271) / 11.7kg
Length
Width
Height
Internals:
| Bottom | Top |
DC-DC Converter
The charger has an integrated DC-DC converter outputting a fixed voltage that seems to vary some between users.
- Capable of at least 1800W of power
- 14.35-15v output (14.5v average)
- Requires battery voltage between 200V and 400V on the DC bus.
- at about 397v the DCDC appears to stop operating
To start the DC-DC converter:
- 12V+ to pin 7 (sense) and GND to pin 10.
- casing connected to common GND
- 12V+ to Pin 8 (IGCT) main power pin.
- Then apply 12V ENABLE signal to pin 4 (DCSW)
Signal Connector
| Pin on 13-pin Connector | DCDC Side Pin Number | Pin on Internal Connector | DCDC Side Color | Color from Schematic | Name | Function |
| 1 | 6 | Orange | NC | Not Connected | ||
| 2 | 5 | Blank | NC | Not Connected | ||
| 3 | 4 | Blue | NC | Not Connected | ||
| 4 | 3 | Grey | Violet-Green | DC SW | Enable DC/DC Converter | |
| 5 | 2 | Light Blue | Pink-Green | CHIN | Serial Protocol to EV Remote WiFi Module | |
| 6 | 1 | Black | Black-Blue | CAN H | CAN High | |
| 7 | 13 | Green | Grey | Sense | Sense for DC/DC Converter (via shared 7.5A fuse) | |
| 8 | 12 | Yellow | Light Green | IGCT | Main +12V Power Supply (via shared 7.5A fuse) | |
| 9 | 11 | White | Blue | CP | Control Pilot from Charge Port | |
| 10 | 10 | Black | Black | GND | Ground | |
| 11 | 9 | Blank | NC | Not Connected | ||
| 12 | 8 | Purple | Brown-Red / Yellow-Black | CHOT | Serial Protocol to EV Remote WiFi Module | |
| 13 | 7 | Red | Red-Blue | CAN L | CAN Low |
Note: Although the above pin numbers, for the 13 pin external connector, match the Mitsubishi wiring diagram the numbers marked on the connector are reversed for each row. Pin 1 is CAN H (Black), pin 6 is NC (orange), pin 7 is CAN L (red ) and pin 13 Sense ( green ). IGCT +12V power should not be powered permanently, this will create problems for using the charger. Recommended to only have the charger powered with Ignition on or charging.
Its not recommended to have permanent 12v supply to DCSW and IGCT as it will cause issues with the charger not functioning properly. The recommended wiring with the ZombieVerter is as follows:
- GND to ground
- SENSE to permanent 12v+
- IGCT to switch 12v+ via a relay controlled by a Zombie output pin set to "HVactive" OR IGCT to a PWM OUT pin set to "HVactive"
- DC SW to Zombie controlled IGN relay
*Current "bug" (as 2.41) where IGN output is not set in op-mode charge when using the ISA shunt. The following wiring will result in DCSW not being pulled high in op-mode charge and thus not enabling the DCDC converter.
This ensures the DCDC only starts drawing HV after precharge is complete, and powers down the OBC when the HV system is off. The Zombie must take care of the proximity pilot detection in order imitate charge mode, which will turn on the HV, Outlander DCDC, and start sending the correct CAN messages for charging.
External Connector
Internal Connector
In case the charger doesn't come with the signal pigtail (which it usually does), the internal signal connector is from the Hirose GT8E series[7], specifically the Hirose GT8E-12DS-HU[8] with Hirose GT8E-2022SCF[9] pins.
The External to Internal wiring harness is as follows:
AC Power Connector
The AC power connector is Yazaki 7283-7350-30 / Toyota 90980-11413[10].
+12V DC Connector
The thread size of the +12V stud of the DC/DC converter is M8. The Mitsubishi part number for the correct cap is "MUC000691".
Charge Control
The OBC is capable of delivering 12A DC. Dependent on your system voltage, the power output may be limited below 3.7 kW. For example, for a 250V system, the power output is only 12*250 = 3kW.
CANBus Messages
The charger has a 3.7k ohm resistance between the CAN H and CAN L pins.
https://github.com/haand22/Mitsubishi_Outlander_PHEV.git
0x286 byte 2 sets the DC charge current, there is a voltage setting on byte 0 and 1. The requested current should be limited to 12A, going above this results in strange current delivery. If 13A is requested, charging does not even start.
Charger will only start charging if EVSE CP is connected and requested current is below EVSE limit.
- Byte 0-1 = Voltage setpoint (Big Endian e.g. 0x0E 0x74 = 3700 = 370v) - Byte 2 = Current in amps x 10
- B0+B1 = 12V Battery voltage (h04DC=12,45V -> 0,01V/bit) - B2+B3 = 12V Supply current (H53=8,3A -> 0,1A/bit) - B4 = Temperature 1 (starts at -40degC, +1degC/bit) - B5 = Temperature 2 (starts at -40degC, +1degC/bit) - B6 = Temperature 3 (starts at -40degC, +1degC/bit) - B7 = Statusbyte (0x20=standby, 0x21=error, 0x22=in operation) - - bit0(LSB) = Error - - bit1 = In Operation - - bit3 = - - bit4 = - - bit5 = Ready - - bit6 = - - bit7(MSB) =
0x389
- B0 = Battery Voltage (as seen by the charger), needs to be scaled x 2, so can represent up to 255*2V; used to monitor battery during charge - B1 = Charger supply voltage, no scaling needed - B6 = AC Supply Current x 10 - B7 = DC side current x 10 (should equal commanded current)
0x38A
Parallel charger control:
Charger voltage control:
CAN_FRAME incoming;
if (Can0.available() > 0) {
Can0.read(incoming);
if (incoming.id == 0x389) {
voltage = incoming.data.bytes[0];
Ctemp = incoming.data.bytes[4];
if (incoming.id == 0x377){
aux1 = incoming.data.bytes[0];
aux2 = incoming.data.bytes[1];
auxvoltage = ((aux1 * 256) + aux2); //recalculate two bit voltage value
void sendCANframeA() {
outframe.id = 0x286; // Set our transmission address ID
outframe.rtr=1; //No request
outframe.data.bytes[0]=0x28;
if(voltage < 193) { // if Charger senses less than 386V
outframe.data.bytes[2]=0x1E;
else { //any other case
outframe.data.bytes[2]=0x00;
outframe.data.bytes[4]=0x00;
outframe.data.bytes[5]=0x00;
outframe.data.bytes[6]=0x0A;
outframe.data.bytes[7]=0x00;
DCDC aux voltage control
if (auxvoltage < 1200) { // if aux voltage is low and DCDC is off
auxState = true; // set the flag to true
elapsedtime = millis();
DCDCauxcharge();
void DCDCauxcharge() {
if ((auxState == true) && (digitalRead(Enable_pin) == LOW)) { // auxvoltage went below 12.2V
digitalWrite(DCDC_active, HIGH);
if (millis() - elapsedtime >= ontime) { // if aux voltage is low and for 5min
auxState = false;
else { // if auxvoltage is OK
auxState = false; // turn off DCDC_active relay
- ↑ https://www.mitsubishi-motors.com.au/blog/a-battery-on-wheels-why-EVs-can-do-more-than-just-take-you-places.html
- ↑ http://mmc-manuals.ru/manuals/outlander_phev/online/Service_Manual_2014/2019/index_M1.htm (Backup: Web Archive)
- ↑ http://mmc-manuals.ru/manuals/outlander_phev/online/Service_Manual_2014/img/90/HKAE0E05AC00ENG.pdf (Backup: Web Archive)
- ↑ http://mmc-manuals.ru/manuals/outlander_phev/online/Service_Manual_2014/img/90/HKAE0E05BC00ENG.pdf (Backup: Web Archive)
- ↑ http://mmc-manuals.ru/manuals/outlander_phev/online/Service_Manual_2014/img/90/HKAE0E05CC00ENG.pdf (Backup: Web Archive)
- ↑ http://mmc-manuals.ru/manuals/outlander_phev/online/Service_Manual_2014/img/90/HKAE0E06AC00ENG.pdf (Backup: Web Archive)
- ↑ https://www.hirose.com/de/product/document?clcode=CL0758-0051-6-00&productname=GT8E-12DS-HU&series=GT8E&documenttype=Catalog&lang=de&documentid=D49379_en (Backup: Web Archive)
- ↑ https://www.mouser.de/ProductDetail/798-GT8E-12DS-HU
- ↑ https://www.mouser.de/ProductDetail/798-GT8E-2022SCF
- ↑ https://www.auto-click.co.uk/7283-7350-30?search=90980-11413 (Backup: Web Archive)
