Category:Rapid Charging
There are 2 commonly used protocols for DC Rapid Charging an EV conversion.
Chademo
CCS
Chademo uses a separate socket to the ac charging port. This is found on Nissan Leaf.
The port on the left is the Chademo port on a Nissan Leaf. This is probably the cheapest standard to get DC rapid charging in your conversion.
There are multiple options for a Chademo controller.
CCS combines the AC charging port with 2 additional pins for DC charging and comes in 2 different socket type, type 1 more common in USA and the type 2 more common in Europe.
The port above is a type 2 CCS socket, for AC charging the normal AC type 2 connector fits in to the top part and the bottom usually has an additional cover for the pins.
You can find a generall overview of CCS and Controller Options list here.
One way of getting CCS working is with the BMW i3 LIM Module
Another way may be using a TP-Link TL-PA4010 ("AV500") and repurposing it as a CCS EVCC.
A third method may be to a board that contains an STM microcontroller and a QCA700x IC[1].
Quick reference of the CCS2 pinout. Looking at the car:
   PP  CP
 L1  PE  N
   L2  L3
  DC-  DC+
As a rule of thumb, CP is on the same side as DC+. PP is the pin that the car supplies about 4.5 V, and on that side is DC-.
Subcategories
This category has the following 3 subcategories, out of 3 total.
Pages in category "Rapid Charging"
The following 7 pages are in this category, out of 7 total.
