Chademo with ESP32-Chademo
Required Parts
https://openinverter.org/forum/viewtopic.php?p=57284 this thread contains a zip of the library versions if you're having trouble building.
Wiring
Wiring setup should be pretty much the same as other Chademo setups. The contactor relay connection will switch the ground side
Settings
The Chademo settings are done via the web interface on the ESP32
The main interface is
