ZV + Leaf Stack wiring diagram
cnstrct
Has thanked: 11 times
Post by cnstrct »
Hey Folks,
While waiting for my Zombiverter to arrive I have been working on a wiring diagram for my bench test.
It's pretty much the same as this one although I'm using an intact stock Leaf battery pack for the bench test and wanted to get the pins correct.
Would be grateful for you all to tear it apart and let me know what I have got wrong :lol:
Thanks!
Leaf stack with zombiverter Openinverter Page
Has thanked: 246 times
Been thanked: 469 times
Re: ZV + Leaf Stack wiring diagram
Nice drawing, your missing t15 “on” switch, pdm working looks right.
cnstrct
Post by cnstrct »
Thanks! makes sense, i remember the switch in one of the videos now.
What did you make this in? Would you mind sharing the file? It’s cleaner than my quick made diagram, would be good for the wiki and what not
GregFordyce
Has thanked: 43 times
Been thanked: 29 times
Post by GregFordyce »
Here's one I added to a few days ago from my build thread. I'm working on wiring my ZV tomorrow so I'll take copies of both of them. What was used to draw that schematic?Image
Peugeot Expert LWB 2009
Zombieverter - Full Gen2 Leaf stack
24kWh & 30kWh Leaf batteries in custom battery box under van
GregFordyce
I've just spotted both diagrams are missing the brake input to terminal 49 of the ZV.
cnstrct
Post by cnstrct »
I used a free Miro account to make mine. Not sure I would have if I had of found yours first GregFordyce :lol: But it is a good process to go through to fully understand the wiring.
Can contribute it to the wiki when it's correct. Thanks for pointing out the lack of brake input GregFordyce.
cnstrct
Post by cnstrct »
Updated diagram with Ignition switch and Brake input.
I have submitted it as a community Miro Template, but will need to wait for review and approval.
If others would like access to a collaborative Miro, PM me your email and I'll add you to my Miro board.
Should I add this to the Wiki page?
cnstrct
Post by cnstrct »
Well I'm getting there. I have my bench setup, throttle, switches, relay and I'm talking to the battery and the Inverter, and I think the PDM.
I got the leaf parts from a wreckers so it was unclear what year things were, so I have been down some dead ends with my wiring diagram, but I believe now I have the correct wiring setup.
The problem I am currently having is that although everything starts up, the battery, inverter and I get into RUN mode, the throttle is not doing anything when pressed. I have of course followed Damian video and calibrated the throttle, I see it going up in the spot values.
I have attached my params file and the spot values in a state where everything is turned on including HV.
params.json
(2.13 KiB) Downloaded 55 times
Zombie-spot-values.xlsx
(14.66 KiB) Downloaded 43 times
It would be amazing if someone could have a look over the wiring, params and spot values and give me a steer in the right direction.
Thanks!
Has thanked: 330 times
Been thanked: 847 times
Please plot Left potnom and right pot and pot 2
Then plot left potnom and right torque
Also your 12V relay and igniton wiring to leaf components is wrong. Here is how to wire it. https://openinverter.org/wiki/Leaf_stac ... ombiverter
Been thanked: 412 times
tom91 wrote: Tue Aug 19, 2025 10:07 am Please plot Left potnom and right pot and pot 2
TNX
Does anyone have connection for gen1 leaf inverter for EM61 motor? I belive it is round green connector, but should have the same pins connected to ZV as the rectangular connector...
cnstrct
Post by cnstrct »
Thanks tom91, I think I have addressed the wiring diagram. I'll come back with the plots over the next few days. Thanks again for the help.
cnstrct wrote: Tue Aug 19, 2025 10:53 am Thanks tom91, I think I have addressed the wiring diagram. I'll come back with the plots over the next few days. Thanks again for the help.
Oh so you are working on the first gen1 inverter? I am very interested
cnstrct
Post by cnstrct »
arber333 wrote: Tue Aug 19, 2025 1:44 pm Oh so you are working on the first gen1 inverter? I am very interested
it's a Gen3 2019 inverter.
cnstrct wrote: Wed Aug 20, 2025 6:39 am it's a Gen3 2019 inverter.
Uh, guys if you remember maybe is there a thread where Gen1 (pre 2012) inverter connector wiring is being discussed? I cant seem to find it, but i remember there was a big discussion for wiring for CAN command at the time...
If we find it i will make a supplementary wiring to go with Gen2 schematic on wiki...
TNX for the help
arber333 wrote: Tue Sep 02, 2025 9:04 am where Gen1 (pre 2012) inverter connector wiring
or is this already gen2?
Here is info in the Thunderstruck VCU contoller wiring info.
https://www.thunderstruck-ev.com/images ... 9908742192
tom91 wrote: Tue Sep 02, 2025 9:08 am ....
That is Gen1 from 2010 to 2012 and it uses round connector similar to PDM.
tom91 wrote: Tue Sep 02, 2025 9:15 am Here is info in the Thunderstruck VCU contoller wiring info.
Really good thanks for the reference! I will test it and then put the difference from Gen2 to wiki.
