cnstrct
Posts: 6 Joined: Fri May 30, 2025 3:20 am
Has thanked: 1 time
Been thanked: 4 times
Post
by cnstrct » Sat Jul 05, 2025 10:58 am
Hey Folks,
While waiting for my Zombiverter to arrive I have been working on a wiring diagram for my bench test.
It's pretty much the same as
this one although I'm using an intact stock Leaf battery pack for the bench test and wanted to get the pins correct.
Would be grateful for you all to tear it apart and let me know what I have got wrong
Thanks!
Leaf stack with zombiverter Openinverter Page
ZV + Leaf Stack wiring diagram
Posts: 1010 Joined: Thu Jan 02, 2020 7:35 pm
Has thanked: 180 times
Been thanked: 372 times
Post
by Bratitude » Sat Jul 05, 2025 11:22 am
Nice drawing, your missing t15 “on” switch, pdm working looks right.
cnstrct
Has thanked: 1 time
Post
by cnstrct » Sat Jul 05, 2025 11:45 am
Thanks! makes sense, i remember the switch in one of the videos now.
Post
by Bratitude » Sat Jul 05, 2025 4:34 pm
What did you make this in? Would you mind sharing the file? It’s cleaner than my quick made diagram, would be good for the wiki and what not
GregFordyce
Posts: 11 Joined: Sun May 23, 2021 5:58 pm
Has thanked: 8 times
Been thanked: 6 times
Post
by GregFordyce » Sat Jul 05, 2025 9:44 pm
Here's one I added to a few days ago from my build thread. I'm working on wiring my ZV tomorrow so I'll take copies of both of them. What was used to draw that schematic?
Peugeot Expert LWB 2009
Zombieverter - Full 80kW Leaf stack
24kWh & 30kWh Leaf batteries in custom battery box under van
GregFordyce
Post
by GregFordyce » Sat Jul 05, 2025 9:54 pm
I've just spotted both diagrams are missing the brake input to terminal 49 of the ZV.
cnstrct
Has thanked: 1 time
Post
by cnstrct » Sat Jul 05, 2025 10:36 pm
I used a free
Miro account to make mine. Not sure I would have if I had of found yours first GregFordyce
But it is a good process to go through to fully understand the wiring.
Can contribute it to the wiki when it's correct. Thanks for pointing out the lack of brake input GregFordyce.
cnstrct
Has thanked: 1 time
Post
by cnstrct » Sun Jul 06, 2025 12:33 am
Updated diagram with Ignition switch and Brake input.
I have submitted it as a community Miro Template, but will need to wait for review and approval.
If others would like access to a collaborative Miro, PM me your email and I'll add you to my Miro board.
Should I add this to the Wiki page?
