Toyota Prius Gen3 Board
Prius Gen3 Control Board v2
Prius Inverter
Control Board
Prius Gen3 Partial
Development History
Vendors
- ?? List of known vendors with support?
Support
Inverter Model Numbers
G9200-47141 Auris 2012, RHD
G9200-47190 Auris F1759-52010 04 ? Forum Thread openinverter.com
G9200-52010 Yaris F1759-52010 04 F1789-52010 154x143mm https://openinverter.org/forum/viewtopic.php?f=14&t=257&p=5828#p5828
Soldering The Breakout Board
Soldering the Main Board
And Conn8, again easy.
[add photo]
Powering up
Checking voltages
Check for ~3.3v here on C32
Finally the 26v
Firmware
Wifi Module Firmware
Main Firmware
For Windows
Atmega328p Firmware
First Run (PWM verify)
Navigate to the Web Interface
Stop the inverter
DC-DC Converter
12v Battery Connection
Motor Connection
Ampseal Socket & Plug
Connecting Resolver
Damien's Prius Gen3 v2 Github
Bill of Materials (Github)
