Motors
Revision as of 22:42, 5 June 2020 by 4markowen (talk | contribs)
OEM Motors
Taken from existing vehicles
Picture Name/link Manufacturer Models Found On Part No/s FWD/RDW/AWD Description
Toyota/Lexus MGR Rear Transaxle Motor Toyota/Lexus
  • Alphard/Vellfire ATH20
  • Alphard/Vellfire AYH30
  • Estima AHR20
  • Harrier MHU38
  • Harrier AVU65
  • Highlander MHU28
  • Highlander MHU48
  • Highlander GVU48
  • Highlander GVU58
  • Kluger MHU28
  • Lexus RX400h MHU38
  • Lexus RX450h GYL15
  • Lexus RX450h GYL25
  • Lexus NX300h AYZ15
  • RAV4 AVA44
Q211
(2FM - Motor code)
FWD
AWD
RWD
For conversion/project purposes the MGR is suitable for lighter models given the torque available or could potentially be used front and/or rear, and/or with a secondary motor.
As the motor was designed to be used occasionally as a rear motor, there is a need or potential need for cooling dependent on the application.
Lexus GS450h Toyota/Lexus Lexus GS450h L110F RWD Popular conversion project motor, the GS450h has two motors as part of a gearbox mated to an ICE engine. MG1 and MG2, one of which is generally used to start the ICE, the second used to provide drive to the wheel in electric only mode.
The input shaft from the ICE can be secured and both motors can then be used to drive the output shaft.
The popularity and conversation around it comes from the fact it is likely to occupy the same space as a rear wheel drive gearbox leaving the majority of the engine bay free and obviously joining to the existing rear propshaft.
Lexus RS600h Toyota/Lexus Lexus RS600h AWD Functionally the same as the GS450h(?) but splits the output front and rear like a traditional 4WD gearbox.
Prius Transaxle Toyota/Lexus Prius FWD Mated to a transversally mounted front wheel drive ICE, the Prius transaxle has two motors contained with it. MG1 and MG2. One of which is generally used to re/start the ICE motor and the second used to drive the car in electric only mode.
The two motors can be combined for greater power output.
The unit itself lends itself to replace the engine and gearbox from FWD front engined vehicles as it largely occupies a similar space as the existing gearbox and frees the space where the engine would sit.
Nissan Leaf Nissan Leaf FWD
Tesla Small Drive Unit Tesla Model S/X FWD
AWD
RWD
Tesla Large Drive Unit Tesla Model S/X FWD
AWD
RWD
Generic Motors
Picture Name/link Manufacturer Part No/s Description
