Leaf stack with zombiverter
The full leaf stack ( motor/inverter, pdm (charger, dcdc, hvjb)) can be controlled with the zombieverter VCU.
All you need is 12v+, enable, and CANbus. Note: You still need the OEM connection between the Inverter and Motor Temperature sensors and Resolver for things to function.
the PDM is not needed for UDC data.
The leaf motor and inverter do not require the PDM to run with the zombieverter, or for UDC measurements.
Wiring
Wiring the zombiverter to the leaf harness
| Description | Zombieverter Pin | PDM pin | inverter pin | battery pin | |
| +12V | Permanent 12v+ | 56 | 18 | 46, 48 | 5, 11, 14, 17 |
| Gnd | permanent 12v - | 55 | pdm case | 47, 49 | 6, 7, 8 |
| Fwd signal | Forward | 54 | |||
| Rev signal | Reverse | 53 | |||
| momentary 12V | Start signal | 52 | |||
| Brake signal | Brake Input | 49 | |||
| +5V | Throttle | 48 | |||
| Throttle signal 1 | Throttle signal 1 | 47 | |||
| Throttle signal 2 | Throttle signal 2 | 46 | |||
| Throttle Gnd | Throttle Gnd | 45 | |||
| Precharge Contactor LS Switch | Negative lead from precharge contactor | 34 | 10 | ||
| Main Contactor LS Switch | Negative lead from main contactor | 33 | 16 | ||
| enable relay | switches enable relay | 32 | 16 | 42 | 31 |
| Neg Contactor LS Switch | Negative lead from negative contactor | 31 | 13 | ||
| CANEXTH | Can 1 High | 28 | 27 | 14 | 1 |
| CANEXTL | Can 1 Low | 27 | 11 | 15 | 2 |
| T15 | Ignition 12V in | 15 | 4 | ||
| proximity pilot | pp for charge port | 29 | |||
| control pilot | cp for charge port | 30 | |||
chademo connector:
HV contactor coil - pin 10
pin 1 to ground
CAN H pin 8 to CAN EXT 3 H
CAN L pin 9 to CAN EXT 3 L
pin 4 to GP out
