Lexus GS450h Drivetrain
Revision as of 16:54, 1 July 2025 by Tom91 (talk | contribs) (Add dummy cavity seals)
  • Two high power inverters, for the 2 motors MG1 capable of handling >430 Amps, and MG2 capable of handling >215 Amps. [1][2]
Weight: 40 lbs
Buck/Boost Converter
Transmission
GS450h transmission layout
MG1 speed is -2.29:1[5]
GS450h shift position sensor
Oil Pump
Overview and location
Wiring and control
GS450h oil pump controller
Pinouts, schematics and notes
Gasket (1) 35142-30010 $14
Wiring Harness Connectors
Inverter Connectors
OEM
90980–12630
8100-3456 (Gold)
8240-0288 (Gold)
2.3 II
0.040"
(Low Insertion
Force Variant)
OEM Wiring Harness
The wiring harness goes by the official name of Engine Room Main Wire. Here are the OEM part numbers for the harness over the years:
82111-30K60 - 2007
82111-30K61 - 2007-2008
82111-30K62 - 2007-2009
82111-30K63 - 2008-2010
82111-30K64 - 2009-2011
82111-30K65 - 2010-2011
Alternatives
Molex MX123 series
Image Part No. Item Quantity
064320-1301 CMC wire cap 1
064323-1039 CP terminal 4
064322-1039 CP terminal 32
064325-1010 CMC plug 8
064325-1023 CMC plug 4
Assembly Instructions
Transmission Connectors
( 0.025"
0.64mm )
8100-3456 (Gold)
8240-0288 (Gold)
( 0.025" 0.64mm )
Female - 7 20-22 AWG /
.3-.5 mm2
16-18 AWG /
.85-1.25 mm2
7116-4029-08 (Gold)
TS 090II Sealed Series
( 0.090" / 2.3mm )
(6mm LIF variant)
(0.025" 0.64 mm)
8100-3456 (Gold)
8240-0288 (Gold)
TS 025 Series Seal Plug
Dummy Grey 7165-0797
Dummy Black 7160-9465
Dummy Brown 7161-9787
Connector Part No. Location
3D Printable Parts
Control Schemes
ZombieVerter VCU
GS450H pinouts and wiring diagram for Zombieverter VCU
Lexus GS450h VCU (deprecated)
See also
Citations
  1. ↑ https://toyota-club.net/files/faq/21-12-01_faq_hybrid_tr_en.htm
  2. ↑ https://www.osti.gov/biblio/947393see p. 62 for locked rotor test. 430A needed for 300Nm of MG2 torque, which is the official published value for the LS600h. (interestingly gs450h published value is 275Nm, although the two should share the same MG units and inverter). MG1 could possibly handle just as much, since copper amount is similar. But the inverter has half as many IGBTs for MG1 as MG2, so the current at system level is possibly halved.
  3. ↑ 3.0 3.1 https://www.osti.gov/servlets/purl/928684
  4. ↑ 4.0 4.1 https://www.osti.gov/servlets/purl/947393
  5. ↑ 5.0 5.1 [1]
  6. ↑ http://carlthomas66.blogspot.com/2016/03/lexus-gs450h-transmission-oil-pump.html (Backup: Web Archive)
  7. ↑ https://www.youtube.com/watch?v=9RXtNTp1AFw&t=154s&ab_channel=DamienMaguire
  8. ↑ https://www.molex.com/mx_upload/family/MX123UserManual.pdf (Backup: Web Archive)
  9. ↑ 9.0 9.1 https://www.evbmw.com/index.php/evbmw-webshop/vcu-boards/gs450h-vcu (Backup: Web Archive)
