Tesla Model S/X Small Drive Unit ("SDU")
Tesla uses the Small Drive Unit (SDU) in dual-motor versions of the Model S/X. The Front SDU (FDU) is found in performance and non-performance dual-motor models, while the Rear SDU (RDSU) is only found in non-performance dual motor models.
Wiring
Low Voltage Data Connector
Housing:
Molex MX150 33472-2002 (key “B”)
Pins:
22 AWG: Molex 33012-2003
18-20 AWG: Molex 33012-2002
14-16 AWG: Molex 33012-2001
High Voltage Power Connectors
Although the connectors are known (Rosenberger HPK series), they are not available through conventional vendors.
Drop-in control board
Dual Pot mode, connect pot 2 to pin 10, BRAKE TRANSDUCER SIGNAL.
| Note: see this thread regarding throttle pedal safety https://openinverter.org/forum/viewtopic.php?p=75841 this applies to the SDU boards. |
Resources
Wiring
MX150 male header receptacle STL on Thingiverse
Buying
Tuning
SDU Tuning Optimization Forum Thread
Original Parameters from Johannes
Application Info
| It is essential that the tripmode parameter is set to 1 "DcSwOn". Also do not use a low value fuse while testing. On over current trips some energy is still stored in the motor and it has nowhere to go if the contactor/fuse opens leading to immediate destruction of your inverter. |
Cooling
Small Front Drive Unit (FDU)
Small Rear Drive Unit (SRDU)
