Lexus GS450h Drivetrain
Revision as of 09:15, 16 November 2024 by Jacobsmess (talk | contribs) (ZombieVerter VCU: Added wiring diagram and pinouts to Zombieverter VCU section)
  • Two high power inverters, for the 2 motors MG1 capable of handling X(?) amps, and MG2 capable of handling Y(?) amps. [1]
Weight: 40 lbs
Buck/Boost Converter
Transmission
GS450h transmission layout
MG1 speed is -2.29:1[4]
GS450h shift position sensor
Oil Pump
Overview and location
The Internal pump and pressure regulator provides a steady 7 Bar oil pressure.[6]
Wiring and control
GS450h oil pump controller
Pinouts, schematics and notes
Gasket (1) 35142-30010 $14
Wiring Harness Connectors
Inverter Connectors
OEM
90980–12630
8100-3456 (Gold)
8240-0288 (Gold)
2.3 II
0.040"
(Low Insertion
Force Variant)
Alternatives
Molex MX123 series
Image Part No. Item Quantity
064320-1301 CMC wire cap 1
064323-1039 CP terminal 4
064322-1039 CP terminal 32
064325-1010 CMC plug 8
064325-1023 CMC plug 4
Assembly Instructions
Instructions on how to assemble the MX123 connector can be found here [7].
Transmission Connectors
( 0.025"
0.64mm )
8100-3456 (Gold)
8240-0288 (Gold)
( 0.025" 0.64mm )
Female - 7 20-22 AWG /
.3-.5 mm2
16-18 AWG /
.85-1.25 mm2
7116-4029-08 (Gold)
TS 090II Sealed Series
( 0.090" / 2.3mm )
(6mm LIF variant)
(0.025" 0.64 mm)
8100-3456 (Gold)
8240-0288 (Gold)
TS 025 Series Seal Plug
Connector Part No. Location
3D Printable Parts
Control Schemes
ZombieVerter VCU
GS450H pinouts and wiring diagram for Zombieverter VCU
