BMW i3 Inverter
BMW I3 inverter
| Pin No | Assigniment | Description |
| 1 | 12V | |
| 2 | BRAKE_IN | |
| 3 | PRECHARGE_OUT | |
| 4 | CANL | |
| 5 | CANH | |
| 6 | DCSW_OUT | |
| 7 | FORWARD_IN | |
| 8 | REVERSE_IN | |
| 9 | 5V (OUT) | |
| 10 | RESOLVER_S2/ENCODER_A | Sin Low (blue) |
| 11 | GND | |
| 12 | RESOLVER_S1 | Sin Hi (red) |
| 13 | THROTTLE1 | |
| 14 | THROTTLE2 | |
| 15 | RESOLVER_R1 | Excitation Hi (yellow) |
| 16 | RESOLVER_S3/ENCODER_B | Cos Hi (white) |
| 17 | MTEMP+ | (blue) |
| 18 | MTEMP- | (grey) |
| 19 | RESOLVER_S4 | Cos Low (brown) |
| 20 | EMCYSTOP_IN | |
| 21 | GND | |
| 22 | RESOLVER_R2 | Excitation Low (green) |
| 23 | START_IN |
Note: colours in description column above are for the BMW cables coming from the motor.
There are 2 variants of the i3. one with the REX and one with out.
the REX variant has a additional 25kw inverter to run the onboard generator.
| Pin No | I/O | Description | Notes | Pin No | I/O | Description | Notes | |
| 1 | 21 | GND Switching Mosfets ? | ||||||
| 2 | I | 32V in | 22 | GND Switching Mosfets ? | ||||
| 3 | I | 32V in | 23 | |||||
| 4 | I | IGBT A HI | 24 | |||||
| 5 | I | IGBT A LOW | 25 | |||||
| 6 | I | CS (ADC) | 26 | GND IGBT Driver ground | ||||
| 7 | I | SDI | 27 | GND IGBT Driver ground | ||||
| 8 | I | SDO | 28 | GND IGBT Driver ground | ||||
| 9 | I | SCK | 29 | GND IGBT Driver ground | ||||
| 10 | I | IGBT B HI | 30 | GND IGBT Driver ground | ||||
| 11 | I | IGBT B LOW | 31 | GND IGBT Driver ground | ||||
| 12 | I | IGBT C HI | 32 | GND IGBT Driver ground | ||||
| 13 | I | IGBT C LOW | 33 | 5V IGBT Driver Power | ||||
| 14 | 34 | 5V IGBT Driver Power | ||||||
| 15 | 35 | I | IGBT PSU 12V on | |||||
| 16 | O | IGBT DRIVER UVW Upper Ready | 36 | O | IGBT Driver Fault | |||
| 17 | O | IGBT DRIVER UVW Lower Ready | 37 | I | 5V LEM Current sensor Power | |||
| 18 | O | Current Sense C Signal | 38 | GND Current sensor Ground | ||||
| 19 | O | Current Sense B Signal | 39 | GND Current sensor Ground | ||||
| 20 | O | Current Sense A Signal | 40 | GND Current sensor Ground |
Motor Resolver & Temperature Sensors
12-pin connector from the motor is an ERNI MiniBridge vertical SMT, part number 294920
