Tesla Model S GEN1 Charger
Tesla GEN1 Onboard AC Charger
The Tesla GEN1 on-board AC charger (OBC) is a single/three phase 10kW AC charger that was fitted originally and primarily in the Tesla Model S, from 2012 through late 2013, when it was replaced with GEN2. GEN1 models are easy to identify, having the word "TESLA" stamped on the top metalwork and no anti-tamper tape; the GEN2 charger lacks the Tesla identifier stamped on the metalwork, and has anti-tamper tape over the seams.
The charger is made up of three 3.3 kw modules, each mounted to a liquid-cooled heat sink that forms the bottom plate/base. This assembly enables both single and multi phase AC charging.
The GEN1 chargers are considered to be more trouble-prone than the later units, and are not as popular for use in EV conversions or ground-up builds, but are used in many OEM installations that continue to need servicing. Examples of OEM installs include the 2012-Sep2013 Tesla Model S, 2012-14 (eg All) Toyota RAV4 EV[1], and 2014-17 MB B250e[2]. As far as is known, these are identical from a hardware perspective[3], but the firmware does differ and is not interchangeable between installations.
Connectors
Charger Connections
Logic Connector X042
Logic Connector X042, 12-pin
The Logic Connector X042 needed to plug into the charger is Molex 19418-0026[4] which is in the MX150L series. This connector features CPA[5] (Connector Position Assurance), a dual-locking feature. For bench-testing, etc., the non-CPA connector is Molex 19418-0038[6]; this connector requires one less operation to disengage, but is less suitable for automotive use or environments where heavy vibration is present.
Telsa Model S (2012-2013) OBC Logic Connector X042 details, from Tesla Service Manual.
Logic Connector X042 (Master charger) and X043 (Slave charger). Molex 19418-0026, female harness connector to mate with X042 Logic Connector on Tesla GEN1 OBC.
Logic Connector X042, Master charger, and X043, Slave charger. Molex 19418-0026, female connector to mate with X042 Logic Connector on Tesla GEN1 OBC.
Molex 19418-0026, female harness-side connector to mate with X042 (male terminals) Logic Connector on Tesla GEN1 OBC (Logic Connector X042 (Master charger) and X043 (Slave charger)). This is the terminals-end view of the housing.
Wire size *
Telsa
Wire Color *
4 CAN + 20 AWG (0.5mm²) RD
6 FC CAN (SWCAN?) 20 AWG (0.5mm²) RD-WH
7 12v GND 20 AWG (0.5mm²) BK
8 Drive inhibit "Prox out", signal to DU to inhibit drive 22 AWG (0.35mm²) OR-PU
10 CAN - 20 AWG (0.5mm²) DB
12 "BMS_12V_in" (BMS enables charger?) 18 AWG (0.75mm²) RD-GY
Input/Output Connectors
Tesla Model S GEN1 OBC Power Connectors
DC (Output) Connector Xnnn
AC (Input) Connector Xnnn
See above DC Output Connector above terminals; it uses the same female terminals.
HVIL Connector Xnnn
  • Only the outside pins are in use. These are used to integrate the HVJB's Lid Reed Switch into the HVIL loop, and this is connected to the HVJB's Lid Reed Switch if the OBC is the only (single) or Master (dual) OBC.
Closeup of Tesla Model S GEN1 HVJB (under rear seat), lid removed, showing the HVIL cover reed switch and HVIL connector that connects to a mating connector on the OBC.
  • For Slave OBC, or all RAV4 EV, this connects to a short loopback harness instead.
Tesla Model S GEN1 OBC HVIL Loopback connector. Used on Tesla Slave OBC installations where the HVJB Lid Reed Switch is already connected to the HVIL circuit via the Master OBC. Also used in RAV4 EV, as there is no HVJB installed at all in those models.
Unknown (HVJB Contactor Control?) Connector Xnnn
Common Issues
  • Two 50A fuses protect the AC input legs: for 1-ph version, one fuse for Neutral, one for Hot/L1. These fuses are a common failure point. The cause of their failure is not known. Some units have their fuses fail more than once. There are two, and typically only one fails at a time. The fuses are "semiconductor fuses", special high-speed parts (opposite of "slow-blow") for use with sensitive electronics, and they sometimes have a hybrid diode-and-fuse symbol, though they have no diode function. The OEM fuse is Ferraz Shawmut 50A 500VAC fuse, part No. A50P50-4[11]. Some people have found that after replacing a single failed fuse, the other one will later fail, so the generic recommendation is to replace them both. Typical pricing is USD$50-100 each in 2023.
Charger Dimensions:
  • nnnmm x nnnmm x nnnmm
  • Weight: 42 lbs (19 kg)
Tesla Part Numbers (TPN):
  • 6009278-00-x
  • 6009354-00-x
Toyota Part Numbers:
  • G9090-0R010 (discontinued)
  • G9090-0R011
MB Part Number(s):
  • TBD
