Tesla Model S GEN1 Charger
Connectors
Charger Connections
Logic Connector X042
The Logic Connector X042 needed to plug into the charger is Molex 19418-0026[3] which is in the MX150L series.
The female terminals for this housing are Molex 19420-0010[4]
| Pin No. | Function | Description | Wire size * | Wire Color* |
| 1 | 12v supply | 18 AWG (0.75mm²) | RD/BR | |
| 3 | HVIL Out | 20 AWG (0.5mm²) | YL/RD | |
| 6 | FC CAN (SWCAN?) | 20 AWG (0.5mm²) | RD/WH | |
| 8 | Drive inhibit | "Prox out", signal to DU to inhibit drive | 22 AWG (0.35mm²) | OR/PU |
| 9 | HVIL In | 20 AWG (0.5mm²) | YL/BR | |
| 12 | "BMS_12V_in" | (BMS enables charger?) | 18 AWG (0.75mm²) | RD/GY |
* = Specifications from 2012 Tesla Model S documentation; other applications may have differing specs.
Input/Output Connectors
AC (Input) Connector Xnnn
The AC Input Connector housing needed to plug into the charger is Molex 42816-0412[5]
The female terminals for this housing are Molex 42815-0134[6] for 8 AWG (8mm²).
DC (Output) Connector Xnnn
The DC Output Connector housing needed to plug into the charger is Molex 42816-0312[7]
Unknown Connector Xnnn
Common Issues
Charger Dimensions:
- nnnmm x nnnmm x nnnmm
- Weight: nn lbs (nn kg)
Tesla Part Numbers (TPN)
- 6009278-00-x
