Tesla Model S GEN1 Charger
The GEN1 chargers are considered to be more trouble-prone than the later units, and are not as popular for use in EV conversions or ground-up builds, but are used in many OEM installations that continue to need servicing. Examples of OEM installs include the 2012-13 Tesla Model S, 2012-14 Toyota RAV4 EV, and 2014 MB B250e. As far as is known, these are identical from a hardware perspective, but the firmware does differ and is not interchangeable between installations.
Important Considerations
Tesla Part Numbers (TPN)[1]
Charger Connections
| Pin No. | Function | Description |
| 1 | 12v supply | |
| 2 | Charge Port: nozzle lock | "InsertEN out" |
| 3 | HVIL Out | |
| 4 | CAN + | |
| 5 | EVSE-Pilot (CP) | |
| 6 | FC CAN (SWCAN?) | |
| 7 | 12v GND | |
| 8 | Drive inhibit | "Prox out", signal to DU to inhibit drive |
| 9 | HVIL In | |
| 10 | CAN - | |
| 11 | EVSE-Prox (PP) | |
| 12 | "BMS_12V_in" | (BMS enables charger?) |
Connector part numbers
Additional Resources
Common Issues
- The Tesla chargers are very sensitive to grounding. The case MUST be connected to vehicle 12v ground AND evse earth/ground when charging. [1]
Charger Dimensions:
