Nissan Leaf transmission
The Nissan Leaf uses a single gear reduction box.
The input splines are the same across both the em61 and em57 motors, but the bolt pattern is different. you can not use a em61 motor with a gen2 gear box and vice versa.
Both gear boxes incorporate an electronic parking brake mechanism.
A helical LSD is available for both gen 1 and 2 gearboxs from nismo japan:
https://www.nismo.co.jp/products/nismo_parts/NEW_PARTS/index_2019.html#a2
for details on bolt paterns check Nissan leaf motor couplers and adapter plates
Gen1 with EM61 motor
gear ratios
17:31 / 17:74
Gen2 with EM57 motor
gear ratios
17:32 / 17:75
