Revision as of 08:38, 14 August 2022 by Bitterandreal (talk | contribs) (new LIM comes without firmware)
The LIM is also available new from BMW spare parts suppliers for € 240. If you get it new it comes without firmware and it needs to be programmed first.
External links
Forum discussion
> CAN logs
> I3 LIM CAN dbc1
BMW I3 HV components
LIM Connector Kit
LIM Compatible Contactors
Connectors and Pinouts
Connector Key (left to right)
Audi 4E0 972 713
TE 1534152-1[1] / 1534151-1
Audi 4F0 972 708
TE 1-1534229-1
1B 16 Pin Connector Hirschmann 805-587-545[2]
Audi 7M0 973 119
TE 1-967616-1[3][4]
X Rubber Seal 1-967067-1[6]
LIM pinout
1B Pinout:
Pin # Function Description
1B-2 -
1B-6 CAN_H Powertrain CAN
1B-7 CAN_L Powertrain CAN
1B-9 VCC Constant Power +12V
1B-10 GND Ground
1B-11 -
1B-12 -
1B-13 -
1B-14 -
2B Pinout:
2B-1 CP Pilot (charge port) ~620 ohms to GND is needed if no original i3 charge port is used!
2B-2 PP Proximity (charge port)
2B-5 GND Ground (charge port)
3B Pinout:
- N/A (for CHAdeMO only)
4B Pinout:
4B-5 U_HV_DC Charge Port DC Voltage (current input 3-20mA?)(1.42V for 0V HV, linear to 4.8V for 500V HV)[8]
4B-12 COV_FB Charge Port Cover Feedback (connect to GND to simulate open cover[9])(To be left floating for contactors weld test)
Wiring Diagram
Note [18Jun2022 ALS]: In the above diagram, some details may be non-current, eg the Charge Port Cover sensor is not shown, but its line @ 4B-12 must be floating (signalling that the Charge Port Cover is closed (?)) in order for the LIM to proceed with its welded contact tests; 4B-12 is tied to Ground (?) to indicate that the cover is open[10].
Wiring notes
This board needs to produce an isolated 3-20mA current signal (or: 1.42V for 0V HV, linear to 4.8V for 500V HV)[11] from the high voltage DC voltage.
A circuit of a voltage sense board is shared here and can be purchased here. Alternative board is available here.
Fast charge contactor
Larger contactor control
Charge port
DUOSIDA / MIDA CCS(2) inlet
Charge port lock
RGB charge indication light
RGB LED
Charge control
Contactor Test
    1. Fault set in 0x272 byte 2
  4. Ignition in 0x12F byte 2 needs to toggle from to OFF 0x88 to ON 0x8a
CCS inlet temperature sensors
CAN communication
0x328 Counter VCU 1s needed
Messages sent by LIM
0x29E CCS charger specs LIM
0x337 Inlet lock status LIM
LIM logs
Observations
LIM hardware
LIM versions
LIM versions
Part No. IEC 61851
J1772 (AC)
61 35 9 346 827 x x BMW i3
61 35 9 346 820 x x BMW i3
61 35 6 828 052 BMW i3 Aug 2019[12]
Mini cooper SE
now
Power Limits
Chips on the LIM board
components
Charging protocols
Signaling circuit
AC charging
CCS DC charging
