BMW i3 Inverter
BMW I3 inverter
Pin No | Assigniment | Description |
1 | 12V | |
2 | BRAKE_IN | |
3 | PRECHARGE_OUT | |
4 | CANL | |
5 | CANH | |
6 | DCSW_OUT | |
7 | FORWARD_IN | |
8 | REVERSE_IN | |
9 | 5V (OUT) | |
10 | RESOLVER_S2/ENCODER_A | Sin Low |
11 | GND | |
12 | RESOLVER_S1 | Sin Hi |
13 | THROTTLE1 | |
14 | THROTTLE2 | |
15 | RESOLVER_R1 | Excitation Hi |
16 | RESOLVER_S3/ENCODER_B | Cos Hi |
17 | MTEMP+ | |
18 | MTEMP- | |
19 | RESOLVER_S4 | Cos Low |
20 | EMCYSTOP_IN | |
21 | GND | |
22 | RESOLVER_R2 | Excitation Low |
23 | START_IN | |
There are 2 variants of the i3. one with the REX and one with out.
the REX variant has a additional 25kw inverter to run the onboard generator.
Pin No | I/O | Description | Notes | Pin No | I/O | Description | Notes | |
1 | 21 | GND Switching Mosfets ? | ||||||
2 | I | 32V in | 22 | GND Switching Mosfets ? | ||||
3 | I | 32V in | 23 | |||||
4 | I | IGBT A HI | 24 | |||||
5 | I | IGBT A LOW | 25 | |||||
6 | I | CS (ADC) | 26 | GND IGBT Driver ground | ||||
7 | I | SDI | 27 | GND IGBT Driver ground | ||||
8 | I | SDO | 28 | GND IGBT Driver ground | ||||
9 | I | SCK | 29 | GND IGBT Driver ground | ||||
10 | I | IGBT B HI | 30 | GND IGBT Driver ground | ||||
11 | I | IGBT B LOW | 31 | GND IGBT Driver ground | ||||
12 | I | IGBT C HI | 32 | GND IGBT Driver ground | ||||
13 | I | IGBT C LOW | 33 | 5V IGBT Driver Power | ||||
14 | 34 | 5V IGBT Driver Power | ||||||
15 | 35 | I | IGBT PSU 12V on | |||||
16 | O | IGBT DRIVER UVW Upper Ready | 36 | O | IGBT Driver Fault | |||
17 | O | IGBT DRIVER UVW Lower Ready | 37 | I | 5V LEM Current sensor Power | |||
18 | O | Current Sense C Signal | 38 | GND Current sensor Ground | ||||
19 | O | Current Sense B Signal | 39 | GND Current sensor Ground | ||||
20 | O | Current Sense A Signal | 40 | GND Current sensor Ground |
