Tesla Model S/X Small Drive Unit ("SDU")
Revision as of 22:57, 15 May 2021 by Luisrayas3 (talk | contribs) (Add link to Tesla Setup FAQ)
The Tesla SDU is used on Model S/X in both rear and front depending on the model.
Front SDU Connectors
Purchase in openinverter shop
Setup FAQ
Drop-in control board
Tesla SDU drop-in board
Wiring connections
Application Info
