Toyota Prius Gen3 Board
Revision as of 06:52, 30 December 2020 by Bratitude (talk | contribs) (formatting)
Prius Gen3 Control Board v2
The Toyota Prius Gen3 Board is an open source project to repurpose 2010-2015 Toyota Prius inverters for DIY EV use. It consists of a open inverter circuit board and programming which replaces the original logic board in the inverter.
This allows independent control of the mg1, mg2, buck/boost converter and dc/dc converter, without communicating with the original Prius logic board.
Prius Inverter
Control Board
Prius Gen3 Partial
Development History
v2c this board uses mg2 power stage for motor control, and mg1 +buck/boost converter as a battery charger
v2d this board allows to use mg1 and mg2 power stages for dual motor control
Vendors
- ?? List of known vendors with support?
Support
Inverter Model Numbers
G9200-47141 Auris 2012, RHD
G9200-47190 Auris F1759-52010 04 ? Forum Thread openinverter.com
G9200-52010 Yaris
Prius C
Soldering The Breakout Board
Soldering the Main Board
And Conn8, again easy.
[add photo]
Powering up
Checking voltages
Check for ~3.3v here on C32
Finally the 26v
Firmware
Wifi Module Firmware
  3. Write code to ESP8266
Programming Firmware
For Windows
Atmega328p Firmware
Inverter Parameters
udcofs 0 DC link 0V offset
Parameters Details
First Run (PWM verify)
Navigate to the Web Interface
Stop the inverter
DC-DC Converter
12v Battery Connection
Motor Connection
IDC Connector
Connections are as follows:
Pin Number Label Description
23 MG2_STATOR_T1 5V analogue input from motor temperature sensor. These are typically variable resistance devices. Connect the other side of the sensor to +5V.
24 MG2_STATOR_T2 5V analogue input from motor temperature sensor. These are typically variable resistance devices. Connect the other side of the sensor to +5V.
28 HV_CON ?
31 EVSE_PROX
32 CONTROL_PILOT
Ampseal Socket & Plug
AMPSeal socket (male) in 3D printed surround with pins marked
22 MOTOR TEMP SENSOR A 5V analogue input from motor temperature sensor. These are typically variable resistance devices. Connect the other side of the sensor to +5V.
23 MOTOR TEMP SENSOR B 5V analogue input from motor temperature sensor. These are typically variable resistance devices. Connect the other side of the sensor to +5V.
27 CHARGER HV DC REQUEST
30 EVSE PROXIMITY SIGNAL
31 EVSE CONTROL PILOT SIGNAL
34 NOT USED
35 NOT USED
Connecting Resolver
Damien's Prius Gen3 v2 Github
Bill of Materials (Github)
