Tesla Model S/X Small Drive Unit ("SDU")
The Tesla SDU is used on Model S/X in both rear and front depending on the model.
Drop-in control board
This board replaces the original board that comes with the OEM Tesla drive train. As opposed to the latter this board lets you use the drive train in the first place and allows you to fine-tune driving behaviour with the usual set of openinverter parameters. It does not restrict you in power output or regen input. You can fully control the board via CAN or via a set of digital and analog inputs.
Application Info
