Toyota Prius Gen3 Board
Revision as of 17:51, 9 July 2020 by Bobbycomelately (talk | contribs) (Added wiring guide for AMPseal and IDC connectors)
Prius Gen3 Control Board v2
Prius Inverter
Control Board
Prius Gen3 Partial
Development History
Vendors
- ?? List of known vendors with support?
Support
Inverter Model Numbers
G9200-47141 Auris 2012, RHD
G9200-47190 Auris F1759-52010 04 ? Forum Thread openinverter.com
G9200-52010 Yaris F1759-52010 04 F1789-52010 154x143mm https://openinverter.org/forum/viewtopic.php?f=14&t=257&p=5828#p5828
Soldering The Breakout Board
Soldering the Main Board
And Conn8, again easy.
[add photo]
Powering up
Checking voltages
Check for ~3.3v here on C32
Finally the 26v
Firmware
Wifi Module Firmware
Main Firmware
For Windows
Atmega328p Firmware
First Run (PWM verify)
Navigate to the Web Interface
Stop the inverter
DC-DC Converter
12v Battery Connection
Motor Connection
IDC Connector
If you are not using the AMPSeal daughterboard, you can connect directly to the 34 pin IDC connector on the EVBMW board. Connections are as follows:
Label Description
12V_IN Provide with +12V supply from battery or power supply for testing
MG2_FORW_IN Active high signal at 12V (switches at >7V) to tell the inverter which way to spin the motor. Take positive feed from 12V battery or supply and wire through a three position switch, with the switched connections running to forward and reverse.
MG2_REVER_IN Active high signal at 12V (switches at >7V) to tell the inverter which way to spin the motor. Take positive feed from 12V battery or supply and wire through a three position switch, with the switched connections running to forward and reverse.
MG2_START Active high signal at 12V (switches at >7V) to start the inverter and move it from pre-charge to run mode. Typically connected to the momentary 'START' position of your ignition switch.
MG2_BRAKE_ON Active high signal at 12V (switches at >7V) to inform the inverter that the car is under braking. Typically takes a feed from the brake switch that also turns on brake lights etc.
CRUISE_IN Active high signal at 12V (switches at >7V) to turn on cruise control mode. This sets the current motor speed as the set point for cruise control. Cruise control is disabled by a signal from the brake switch.
VCC_5V +5V supply for temperature and throttle sensors
MG2_ACCEL 5V analogue input from first channel of throttle sensor. These typically take a 5V supply and ground and return to this pin a variable voltage that indicates throttle position.
MG2_BRAKE_TRANS 5V analogue input from second channel of throttle sensor. These typically take a 5V supply and ground and return to this pin a variable voltage that indicates throttle position.
GND Common ground for 12V supply or 5V return.
CAN_EXT_H CANBus digital communication connection for remote interface with inverter
CAN_EXT_L CANBus digital communication connection for remote interface with inverter
MG2_ENC_1 Can be either digital input for encoder (in which case, connect the relevant encoder output here and provide the device with 5V and ground), or one of the two connections for the SIN winding if you are using a resolver for motor position.
MG2_ENC_2 Can be either digital input for encoder (in which case, connect the relevant encoder output here and provide the device with 5V and ground), or one of the two connections for the COS winding if you are using a resolver for motor position.
MG2_COSA Connect SIN winding of motor resolver here and to Encoder Channel A
MG2_SINA Connect COS winding of motor resolver here and to Encoder Channel B
MG2_EXCA Connect exciter winding of motor resolver here and to ground
MG2_STATOR_T1 5V analogue input from motor temperature sensor. These are typically variable resistance devices. Connect the other side of the sensor to +5V.
MG2_STATOR_T2 5V analogue input from motor temperature sensor. These are typically variable resistance devices. Connect the other side of the sensor to +5V.
MAIN_CON 5V output to switch main HV contactor. Note that you cannot switch these 12V devices directly from this output. You will need either a transistor or smaller relay arrangement to provide the appropriate voltage/current.
PRECHG_RLY 5V output to switch the pre-charge relay. Note you cannot switch these 12V devices directly from this output. You will need either a transistor or smaller relay arrangement to provide the appropriate voltage/current.
AC_CON 5V output to switch the main charger AC input relay. Note you cannot switch these 12V devices directly from this output. You will need either a transistor or smaller relay arrangement to provide the appropriate voltage/current.
HV_CON ?
AC_PRECH 5V output to switch the charger AC input pre-charge relay. Note you cannot switch these 12V devices directly from this output. You will need either a transistor or smaller relay arrangement to provide the appropriate voltage/current.
EVSE_PROX
CONTROL_PILOT
CHG_CANH CANBus digital communication connection for remote interface with charger
CHG_CANL CANBus digital communication connection for remote interface with charger
Ampseal Socket & Plug
AMPSeal Pinout Label Description
12V SUPPLY POSITIVE Provide with +12V supply from battery or power supply for testing
GROUND Common ground for 12V supply or 5V return
FORWARD DIRECTION SIGNAL Active high signal at 12V (switches at >7V) to tell the inverter which way to spin the motor. Take positive feed from 12V battery or supply and wire through a three position switch, with the switched connections running to forward and reverse.
REVERSE DIRECTION SIGNAL Active high signal at 12V (switches at >7V) to tell the inverter which way to spin the motor. Take positive feed from 12V battery or supply and wire through a three position switch, with the switched connections running to forward and reverse.
START SIGNAL Active high signal at 12V (switches at >7V) to start the inverter and move it from pre-charge to run mode. Typically connected to the momentary 'START' position of your ignition switch.
BRAKE DIGITAL SIGNAL Active high signal at 12V (switches at >7V) to inform the inverter that the car is under braking. Typically takes a feed from the brake switch that also turns on brake lights etc.
CRUISE CONTROL SIGNAL Active high signal at 12V (switches at >7V) to turn on cruise control mode. This sets the current motor speed as the set point for cruise control. Cruise control is disabled by a signal from the brake switch.
5V OUT +5V supply for temperature and throttle sensors
ACCELERATOR CHAN 1 INPUT 5V analogue input from first channel of throttle sensor. These typically take a 5V supply and ground and return to this pin a variable voltage that indicates throttle position.
ACCELERATOR CHAN 2 INPUT 5V analogue input from second channel of throttle sensor. These typically take a 5V supply and ground and return to this pin a variable voltage that indicates throttle position.
GROUND Common ground for 12V supply or 5V return.
INVERTER CAN HIGH CANBus digital communication connection for remote interface with inverter
INVERTER CAN LOW CANBus digital communication connection for remote interface with inverter
+5V OUT +5V supply for temperature and throttle sensors
ENCODER CHAN A Can be either digital input for encoder (in which case, connect the relevant encoder output here and provide the device with 5V and ground), or one of the two connections for the SIN winding if you are using a resolver for motor position.
ENCODER CHAN B Can be either digital input for encoder (in which case, connect the relevant encoder output here and provide the device with 5V and ground), or one of the two connections for the COS winding if you are using a resolver for motor position.
RESOLVER SIN Connect SIN winding of motor resolver here and to Encoder Channel A
RESOLVER COS Connect COS winding of motor resolver here and to Encoder Channel B
RESOLVER EXC Connect exciter winding of motor resolver here and to ground
MOTOR TEMP SENSOR A 5V analogue input from motor temperature sensor. These are typically variable resistance devices. Connect the other side of the sensor to +5V.
MOTOR TEMP SENSOR B 5V analogue input from motor temperature sensor. These are typically variable resistance devices. Connect the other side of the sensor to +5V.
MAIN HV CONTACTOR 5V output to switch main HV contactor. Note that you cannot switch these 12V devices directly from this output. You will need either a transistor or smaller relay arrangement to provide the appropriate voltage/current.
HV PRECHARGE RELAY 5V output to switch the pre-charge relay. Note you cannot switch these 12V devices directly from this output. You will need either a transistor or smaller relay arrangement to provide the appropriate voltage/current.
CHARGER AC INPUT RELAY 5V output to switch the main charger AC input relay. Note you cannot switch these 12V devices directly from this output. You will need either a transistor or smaller relay arrangement to provide the appropriate voltage/current.
CHARGER HV DC REQUEST
CHARGER AC PRECHARGE RELAY 5V output to switch the charger AC input pre-charge relay. Note you cannot switch these 12V devices directly from this output. You will need either a transistor or smaller relay arrangement to provide the appropriate voltage/current.
EVSE PROXIMITY SIGNAL
EVSE CONTROL PILOT SIGNAL
CHARGER CAN HIGH CANBus digital communication connection for remote interface with charger
CHARGER CAN LOW CANBus digital communication connection for remote interface with charger
NOT USED
NOT USED
Connecting Resolver
Damien's Prius Gen3 v2 Github
Bill of Materials (Github)
