Batteries
Wiki Category
Category:Battery
Battery pack specification
Capacity (kWh)
Voltage (V)
Maximum current (A)
Mass (kg)
Volume (L)
Cell chemistry
LiFePO4 pouch cells
General build requirements
Compression
*placeholder*
LiFePO4 prismatic cells
*placeholder*
LiFePO4 cylindrical cells
*placeholder*
LiFePO4 cell ageing
Lithium-ion
  • Overcharging
Li-ion pouch cells
Cell voltages / Type
OEM modules
Manufacturer Model Years Capacity (kWh) Weight (kg) w (mm) d (mm) h (mm) Gravimetric (kg/kWh) Volumetric (L/kWh) Voltage (V) Current (cont A) Current (peak A) Cell arrangement Cell type Chemistry OEM numbers
Tesla Model S 85kWh 2014-2016 5.3 26 690 315 80 4.9 3.3 22.8 500 750 6s74p 18650 Li-ion
Tesla Model S 100kWh 2016-2018 6.4 28 680 315 80 4.4 2.7 22.8 870 6s86p 18650 Li-ion
Tesla Model 3 LR (inner) 2017- 19.2 98.9 1854 292 90 5.2 2.5 91.1 971 25s46p 2170 Li-ion
Tesla Model 3 LR (outer) 2017- 17.7 86.6 1715 292 90 4.9 2.5 83.9 971 23s46p 2170 Li-ion
Tesla Model 3 SR (inner) 2019- 13.0 58.9 1385 326 90 3.7 91.1 603 24s31p 2170 Li-ion
Tesla Model 3 SR (outer) 2019- 12.0 58.9 1380 344 90 3.8 83.9 603 24s31p 2170 Li-ion
Tesla Model 3 LFP (inner) 2021- 13.38 86 1860 323 81 6.4 83 161 23s Prismatic LiFePo4
Tesla Model 3 LFP (outer) 2021- 15.07 93.48 1948 323 81 6.2 93.5 161 25s Prismatic LiFePo4
BMW i3 60Ah 2014-2016 2 13 410 310 150 6.5 9.5 28.8 210 350 8s2p Prismatic Li-ion
BMW i3 94Ah 2017-2018 4.15 28 410 310 150 6.7 4.6 45.6 409 12s Prismatic Li-ion 61 27 8 647 912
BMW i3 120Ah 2018-2022 5.3 28 410 310 150 5.3 3.6 45.6 360 12s Prismatic Li-ion 61 21 8 851 706
BMW iX3 2021-2025 7,66 36,2 570 360 110 4.72 2.94 33 9s Prismatic Li-ion 9426634
BMW PHEV 26Ah 2017-2019 1.53 13.05 364 183 110 8.824 58.6 16s Prismatic NCM 811
BMW PHEV 34Ah 2019-2022 2.0 13.05 368 178 102 6.525 3.34 59.0 16s Prismatic NCM 811
BMW PHEV 68Ah 2019-2023 2.0 13.05 368 178 102 6.525 3.34 29.5 8s Prismatic NCM 811
Chevrolet Volt 2012 2011-2015 4 38 470 180 280 9.5 5.9 88.8 676 24s3p Pouch Li-ion
Jaguar iPace 2018- 2.5 12 340 155 112 4.8 2.4 10.8 720 1200 3s4p Pouch Li-ion
MG ZS EV 64.6Ah 2021- 2.74 13.6 390 150 115 4.969 2.338 21.9 125 375 6s2p Prismatic NMC
Mitsubishi Outlander PHEV 2013-2016 2.4 26 646 184 130 10.8 6.4 60 240 16s Li-ion
Nissan Leaf 24kWh 2013-2016 0.5 3.65 300 222 34 7.3 4.5 7.2 130 228 2s2p Pouch Li-ion LMO
Nissan Leaf 30kWh 2016-2018 1.25 ~8.3 300 222 34 ~6.64 3.6 14.4 4s2p Pouch Li-ion
Nissan Leaf 40kWh 2018-2024 1.6 8.7 300 222 68 5.4 2.8 14.4 314 4s2p Pouch Li-ion NMC
Nissan Leaf 62kWh 2019-2024 2.58 14.4 4s3p Li-ion
Porsche Taycan 2020-2024 2.77 12.7 390 155 115 4.9 2.3 21.9 360 600 6s2p Pouch Li-ion
PSA/Opel eCMP Peugeot E-208, Corsa E (Forum post) 2019 2.73 12.7 390 150 115 4.6 2.5 21.9 6s2p / 6s1p Prismatic Li-ion
Toyota Prius Prime 2017- 1.76 16.9 597 152 121 9.6 6.24 70.3
Renault Kangoo 2017- 3 16 310 210 140 5.3 3.03 29.6 8s Li-ion
Volvo V60/S60 2012-2018 1.3 11 120 310 185 8.46 160 10S Poucch Li-ion
Volvo XC90 T8 2015- 2.01 12.1 300 180 150 6.0 4.0 59.2 170 340 16s Li-ion
VW Passat GTE 28Ah 2015-2019 2.48 23.4 (with cooler plate)
10.8kg single
410 (C/P)
355 (S)
235 (C/P)
150 (S)
150 (C/P)
108 (S)
VW Golf GTE 2014-2020 1.086 9.8 355 152 110 9.02 5.5 44 12s Prismatic Li-ion 5QE 915 591 H
VW Touareg 14,1 kWh 2020- 1.76 12.3 385 150 108 7.0 3.5 45.25 13s Prismatic Li-ion
VW ID.3/ID.4 55kWh, 62kWh 2019- 6.85 32 225 590 110 4.67 2.13 44.4 12s2p 0Z1 915 592 / 0Z1 915 692
VW ID.3/ID.4 82kWh 2021- 6.85 32 225 590 110 4.67 2.13 29.6 8s3p 0Z1 915 599
VW VW Golf VIII hybrid, Cupra Leon Hybrid 26kWh 2024- 6.5 30 225 600 110 4.6 87.6 73 220 24s1p Prismatic Li-ion NMC 5WA915589L
