Batteries
Wiki Category
Battery pack specification
Capacity (kWh)
Voltage (V)
Maximum current (A)
Mass (kg)
Volume (L)
Cell chemistry
LiFePO4 pouch cells
General build requirements
Compression
*placeholder*
LiFePO4 prismatic cells
*placeholder*
LiFePO4 cylindrical cells
*placeholder*
LiFePO4 cell ageing
Lithium-ion
- Overcharging
Li-ion pouch cells
OEM modules
| Manufacturer | Model | Years | Capacity (kWh) | Weight (kg) | w (mm) | d (mm) | h (mm) | Gravimetric (kg/kWh) | Volumetric (L/kWh) | Voltage (V) | Current (cont A) | Current (peak A) | Cell arrangement | Cell type | Chemistry | OEM numbers |
| Tesla | Model S 85kWh | 2014-2016 | 5.3 | 26 | 690 | 315 | 80 | 4.9 | 3.3 | 22.8 | 500 | 750 | 6s74p | 18650 | Li-ion | |
| Tesla | Model S 100kWh | 2016-2018 | 6.4 | 28 | 680 | 315 | 80 | 4.4 | 2.7 | 22.8 | 870 | 6s86p | 18650 | Li-ion | ||
| Tesla | Model 3 LR (inner) | 2017- | 19.2 | 98.9 | 1854 | 292 | 90 | 5.2 | 2.5 | 91.1 | 971 | 25s46p | 2170 | Li-ion | ||
| Tesla | Model 3 LR (outer) | 2017- | 17.7 | 86.6 | 1715 | 292 | 90 | 4.9 | 2.5 | 83.9 | 971 | 23s46p | 2170 | Li-ion | ||
| Tesla | Model 3 SR (inner) | 2019- | 13.0 | 58.9 | 1385 | 326 | 90 | 3.7 | 91.1 | 603 | 24s31p | 2170 | Li-ion | |||
| Tesla | Model 3 SR (outer) | 2019- | 12.0 | 58.9 | 1380 | 344 | 90 | 3.8 | 83.9 | 603 | 24s31p | 2170 | Li-ion | |||
| Tesla | Model 3 LFP (inner) | 2021- | 13.38 | 86 | 1860 | 323 | 81 | 6.4 | 83 | 161 | 23s | Prismatic | LiFePo4 | |||
| Tesla | Model 3 LFP (outer) | 2021- | 15.07 | 93.48 | 1948 | 323 | 81 | 6.2 | 93.5 | 161 | 25s | Prismatic | LiFePo4 | |||
| BMW | i3 60Ah | 2014-2016 | 2 | 13 | 410 | 310 | 150 | 6.5 | 9.5 | 28.8 | 210 | 350 | 8s2p | Prismatic | Li-ion | |
| BMW | i3 60Ah (12S) | 2.7 | 25 | 410 | 310 | 150 | 9.26 | 7.1 | 45.6 | 310 | 12s | Prismatic | Li-ion | 61 27 7 625 066 | ||
| BMW | i3 94Ah | 2017-2018 | 4.15 | 28 | 410 | 310 | 150 | 6.7 | 4.6 | 45.6 | 409 | 12s | Prismatic | Li-ion | 61 27 8 647 912 | |
| BMW | i3 120Ah | 2018-2022 | 5.3 | 28 | 410 | 310 | 150 | 5.3 | 3.6 | 45.6 | 360 | 12s | Prismatic | Li-ion | 61 21 8 851 706 | |
| BMW | iX3 | 2021-2025 | 7,66 | 36,2 | 570 | 360 | 110 | 4.72 | 2.94 | 33 | 9s | Prismatic | Li-ion | 9426634 | ||
| BMW | PHEV 26Ah | 2017-2019 | 1.53 | 13.05 | 364 | 183 | 110 | 8.824 | 58.6 | 16s | Prismatic | NCM 811 | ||||
| BMW | PHEV 34Ah | 2019-2022 | 2.0 | 13.05 | 368 | 178 | 102 | 6.525 | 3.34 | 59.0 | 16s | Prismatic | NCM 811 | |||
| BMW | PHEV 68Ah | 2019-2023 | 2.0 | 13.05 | 368 | 178 | 102 | 6.525 | 3.34 | 29.5 | 8s | Prismatic | NCM 811 | |||
| Chevrolet | Volt 2012 | 2011-2015 | 4 | 38 | 470 | 180 | 280 | 9.5 | 5.9 | 88.8 | 676 | 24s3p | Pouch | Li-ion | ||
| Jaguar | iPace | 2018- | 2.5 | 12 | 340 | 155 | 112 | 4.8 | 2.4 | 10.8 | 720 | 1200 | 3s4p | Pouch | Li-ion | |
| MG | ZS EV 64.6Ah | 2021- | 2.74 | 13.6 | 390 | 150 | 115 | 4.969 | 2.338 | 21.9 | 125 | 375 | 6s2p | Prismatic | NMC | |
| Mitsubishi | Outlander PHEV | 2013-2016 | 2.4 | 26 | 646 | 184 | 130 | 10.8 | 6.4 | 60 | 240 | 16s | Li-ion | |||
| Nissan | Leaf 24kWh | 2013-2016 | 0.5 | 3.65 | 300 | 222 | 34 | 7.3 | 4.5 | 7.2 | 130 | 228 | 2s2p | Pouch | Li-ion LMO | |
| Nissan | Leaf 30kWh | 2016-2018 | 1.25 | ~8.3 | 300 | 222 | 34 | ~6.64 | 3.6 | 14.4 | 4s2p | Pouch | Li-ion | |||
| Nissan | Leaf 40kWh | 2018-2024 | 1.6 | 8.7 | 300 | 222 | 68 | 5.4 | 2.8 | 14.4 | 314 | 4s2p | Pouch | Li-ion NMC | ||
| Nissan | Leaf 62kWh | 2019-2024 | 2.58 | 14.4 | 4s3p | Li-ion | ||||||||||
| Porsche | Taycan | 2020-2024 | 2.77 | 12.7 | 390 | 155 | 115 | 4.9 | 2.3 | 21.9 | 360 | 600 | 6s2p | Pouch | Li-ion | |
| PSA/Opel eCMP | Peugeot E-208, Corsa E (Forum post) | 2019 | 2.73 | 12.7 | 390 | 150 | 115 | 4.6 | 2.5 | 21.9 | 6s2p / 6s1p | Prismatic | Li-ion | |||
| Toyota | Prius Prime | 2017- | 1.76 | 16.9 | 597 | 152 | 121 | 9.6 | 6.24 | 70.3 | ||||||
| Renault | Kangoo | 2017- | 3 | 16 | 310 | 210 | 140 | 5.3 | 3.03 | 29.6 | 8s | Li-ion | ||||
| Volvo | V60/S60 | 2012-2018 | 1.3 | 11 | 120 | 310 | 185 | 8.46 | 160 | 10S | Poucch | Li-ion | ||||
| Volvo | XC90 T8 | 2015- | 2.01 | 12.1 | 300 | 180 | 150 | 6.0 | 4.0 | 59.2 | 170 | 340 | 16s | Li-ion | ||
| VW | Passat GTE 28Ah | 2015-2019 | 2.48 | 23.4 (with cooler plate)
10.8kg single |
410 (C/P)
355 (S) |
235 (C/P)
150 (S) |
150 (C/P)
108 (S) |
9.4 | 5.5 | 88.8 | 24s | Prismatic | Li-ion | |||
| VW | Golf GTE | 2014-2020 | 1.086 | 9.8 | 355 | 152 | 110 | 9.02 | 5.5 | 44 | 12s | Prismatic | Li-ion | 5QE 915 591 H | ||
| VW | Touareg 14,1 kWh | 2020- | 1.76 | 12.3 | 385 | 150 | 108 | 7.0 | 3.5 | 45.25 | 13s | Prismatic | Li-ion | |||
| VW | ID.3/ID.4 55kWh, 62kWh | 2019- | 6.85 | 32 | 225 | 590 | 110 | 4.67 | 2.13 | 44.4 | 12s2p | 0Z1 915 592 / 0Z1 915 692 | ||||
| VW | ID.3/ID.4 82kWh | 2021- | 6.85 | 32 | 225 | 590 | 110 | 4.67 | 2.13 | 29.6 | 8s3p | 0Z1 915 599 | ||||
| VW | VW Golf VIII hybrid, Cupra Leon Hybrid 26kWh | 2024- | 6.5 | 30 | 225 | 600 | 110 | 4.6 | ||||||||
| 87.6 | 73 | 220 | 24s1p | Prismatic | Li-ion NMC | 5WA915589L |
- ↑ https://www.orionbms.com/manuals/pdf/parallel_strings.pdf (Backup: Web Archive)
- ↑ https://endless-sphere.com/forums/viewtopic.php?f=14&t=38761&start=900 (Backup: Web Archive)
- ↑ https://www.americanmicroinc.com/fish-paper/ (Backup: Web Archive)
- ↑ https://www.rogerscorp.com/elastomeric-material-solutions/poron-industrial-polyurethanes (Backup: Web Archive)
- ↑ 5.0 5.1 https://endless-sphere.com/forums/memberlist.php?mode=viewprofile&u=33107
- ↑ 6.0 6.1 https://endless-sphere.com/forums/viewtopic.php?f=14&t=38761 (Backup: Web Archive)
- ↑ https://earthshipbiotecture.com/a-lithium-ion-battery-primer/ (Backup: Web Archive)
- ↑ https://kokam.com/en/product/cell/lithium-ion-battery (Backup: Web Archive)
