Batteries
Revision as of 16:08, 20 December 2024 by Tom91 (talk | contribs)
Wiki Category
Category:Battery
Battery pack specification
Capacity (kWh)
Voltage (V)
Maximum current (A)
Mass (kg)
Volume (L)
Cell chemistry
LiFePO4 pouch cells
General build requirements
Compression
*placeholder*
LiFePO4 prismatic cells
*placeholder*
LiFePO4 cylindrical cells
*placeholder*
LiFePO4 cell ageing
Lithium-ion
  • Overcharging
Li-ion pouch cells
Cell voltages / Type
OEM modules
Manufacturer Model Capacity (kWh) Weight (kg) w (mm) d (mm) h (mm) Gravity (kg/kWh) Volume (L/kWh) Voltage (V) Current (cont A) Current (peak A) Cell arrangement Cell type Chemistry
Tesla Model S 85kWh 5.3 26 690 315 80 4.9 3.3 22.8 500 750 74p6s 18650 Li-ion
Tesla Model S 100kWh 6.4 28 680 315 80 4.4 2.7 22.8 870 86p6s 18650 Li-ion
Tesla Model 3 LR (inner) 19.2 98.9 1854 292 90 5.2 2.5 91.1 971 46p25s 2170 Li-ion
Tesla Model 3 LR (outer) 17.7 86.6 1715 292 90 4.9 2.5 83.9 971 46p23s 2170 Li-ion
Tesla Model 3 SR (inner) 13.0 58.9 1385 326 90 3.7 91.1 603 31p24s 2170 Li-ion
Tesla Model 3 SR (outer) 12.0 58.9 1380 344 90 3.8 83.9 603 31p24s 2170 Li-ion
Tesla Model 3 LFP (inner) 13.38 86 1860 323 81 6.4 83 161 23s Prismatic LiFePo4
Tesla Model 3 LFP (outer) 15.07 93.48 1948 323 81 6.2 93.5 161 25s Prismatic LiFePo4
Calb 4S3P 2.19 12 355 151 108 5.5 2.6 14.6 900 3p4s Pouch Li-ion
Calb 6S2P 2.19 12 355 151 108 5.5 2.6 22.2 600 2p6s Pouch Li-ion
Chevrolet Volt 2012 4 38 470 180 280 9.5 5.9 88.8 676 3p24s Pouch Li-ion
BMW i3 60Ah 2 13 410 310 150 6.5 9.5 28.8 210 350 2p8s Prismatic Li-ion
BMW i3 94Ah 4.15 28 410 310 150 6.7 4.6 45.6 409 12s Prismatic Li-ion
BMW i3 120Ah 5.3 28 410 310 150 5.3 3.6 45.6 360 12s Prismatic Li-ion
BMW PHEV 34Ah 2.0 13.05 368 178 102 6.525 3.34 59.0 16s Prismatic NCM 811
BMW PHEV 68Ah 2.0 13.05 368 178 102 6.525 3.34 29.5 8s Prismatic NCM 811
Jaguar iPace 2.5 12 340 155 112 4.8 2.4 10.8 720 1200 4p3s Pouch Li-ion
LG 4P3S 2.6 12.8 357 151 110 4.9 2.3 11 4p3s Pouch Li-ion
MG ZS EV (2021) 64.6Ah 2.74 13.6 390 150 115 4.969 2.338 21.9 125 375 6s2p Prismatic NMC
Nissan Leaf 24kWh 0.5 3.65 300 222 34 7.3 4.5 7.2 130 228 2p2s Pouch Li-ion LMO
Nissan Leaf 30kWh 1.25 300 222 34 3.6 14.4 2p4s Pouch Li-ion
Nissan Leaf 40kWh 1.6 8.7 300 222 68 5.4 2.8 14.4 314 2p4s Pouch Li-ion NMC
Nissan Leaf 62kWh 2.58 14.4 3p4s Li-ion
Porsche Taycan 2.77 12.7 390 155 115 4.9 2.3 21.9 360 600 2p6s Pouch Li-ion
PSA/Opel Peugeot E-208, Corsa E 2.73 12.7 390 150 115 4.6 2.5 21.9 2p6s / 1p6s Prismatic Li-ion
VW Passet GTE 2.48 23.4 (with cooler plate)
10.8kg single
410 (C/P)
355 (S)
235 (C/P)
150 (S)
150 (C/P)
108 (S)
VW Golf GTE 1.086 9.8 355 152 110 9.02 5.5 44 12s Prismatic Li-ion
VW Touareg 14,1 kWh 1.76 12.3 385 150 108 7.0 3.5 45.25 13s Prismatic Li-ion
VW id3/id4 55kWh, 62kWh 6.85 32 225 590 110 4.67 2.13 44.4 12s2p
VW id3/id4 82kWh 6.85 32 225 590 110 4.67 2.13 29.6 8s3p
Toyota Prius Prime 1.76 16.9 597 152 121 9.6 6.24 70.3
Renault Kangoo 3 16 310 210 140 5.3 3.03 29.6 8s Li-ion
