Nissan Leaf ZE1 AC compressor
From Leaf model year 2017-2023
It is label Denso S1 ESB27C
Low voltage Connector
Connector is believe to be Sumitomo 6189-1083 !!!to be verified
The pinout is as follows:
Left most pin 12V ign, middle is ground, right is LIN
High Voltage Connector
HV, Red is positive Blue is negative
LIN Bus Info
Lin Speed 19200kbps
Message rate 100Hz (0.1 S between same ID)
Checksum: Enhanced
Compressor info ID 0x09 Length 8
!!!Content unkown
Control ID 0x07 length 8
OFF: 0x00,0x00,0xFD,0xFF,0xFF,0xFF,0xFF,0xFF
Run: 0x00,0x05,0xFD,0xFF,0xFF,0xFF,0xFF,0xFF
First two bytes control speed ? !!!to be verified
