Batteries
Battery pack specification
Capacity (kWh)
Voltage (V)
Maximum current (A)
Mass (kg)
Volume (L)
Cell chemistry
LiFePO4 pouch cells
General build requirements
Compression
*placeholder*
LiFePO4 prismatic cells
*placeholder*
LiFePO4 cylindrical cells
*placeholder*
LiFePO4 cell ageing
Lithium-ion
- Overcharging
Li-ion pouch cells
OEM modules
| Manufacturer | Model | Capacity (kWh) | Weight (kg) | w (mm) | d (mm) | h (mm) | Gravity (kg/kWh) | Volume (L/kWh) | Voltage (V) | Current (cont A) | Current (peak A) | Cell arrangement | Cell type | Chemistry |
| Tesla | Model S 85kWh | 5.3 | 26 | 690 | 315 | 80 | 4.9 | 3.3 | 22.8 | 500 | 750 | 74p6s | 18650 | Li-ion |
| Tesla | Model S 100kWh | 6.4 | 28 | 680 | 315 | 80 | 4.4 | 2.7 | 22.8 | 870 | 86p6s | 18650 | Li-ion | |
| Tesla | Model 3 LR (inner) | 19.2 | 98.9 | 1854 | 292 | 90 | 5.2 | 2.5 | 91.1 | 971 | 46p25s | 2170 | Li-ion | |
| Tesla | Model 3 LR (outer) | 17.7 | 86.6 | 1715 | 292 | 90 | 4.9 | 2.5 | 83.9 | 971 | 46p23s | 2170 | Li-ion | |
| Tesla | Model 3 SR (inner) | 13.0 | 58.9 | 1385 | 326 | 90 | 3.7 | 91.1 | 603 | 31p24s | 2170 | Li-ion | ||
| Tesla | Model 3 SR (outer) | 12.0 | 58.9 | 1380 | 344 | 90 | 3.8 | 83.9 | 603 | 31p24s | 2170 | Li-ion | ||
| Tesla | Model 3 LFP (inner) | 13.38 | 86 | 1860 | 323 | 81 | 6.4 | 83 | 161 | 23s | Prismatic | LiFePo4 | ||
| Tesla | Model 3 LFP (outer) | 15.07 | 93.48 | 1948 | 323 | 81 | 6.2 | 93.5 | 161 | 25s | Prismatic | LiFePo4 | ||
| Calb | 4S3P | 2.19 | 12 | 355 | 151 | 108 | 5.5 | 2.6 | 14.6 | 900 | 3p4s | Pouch | Li-ion | |
| Calb | 6S2P | 2.19 | 12 | 355 | 151 | 108 | 5.5 | 2.6 | 22.2 | 600 | 2p6s | Pouch | Li-ion | |
| Chevrolet | Volt 2012 | 4 | 38 | 470 | 180 | 280 | 9.5 | 5.9 | 88.8 | 676 | 3p24s | Pouch | Li-ion | |
| BMW | i3 60Ah | 2 | 13 | 410 | 310 | 150 | 6.5 | 9.5 | 28.8 | 210 | 350 | 2p8s | Prismatic | Li-ion |
| BMW | i3 94Ah | 4.15 | 28 | 410 | 310 | 150 | 6.7 | 4.6 | 45.6 | 409 | 12s | Prismatic | Li-ion | |
| BMW | i3 120Ah | 5.3 | 28 | 410 | 310 | 150 | 5.3 | 3.6 | 45.6 | 360 | 12s | Prismatic | Li-ion | |
| BMW | PHEV 34Ah | 2.0 | 13.05 | 368 | 178 | 102 | 6.525 | 3.34 | 59.0 | 16s | Prismatic | NCM 811 | ||
| BMW | PHEV 68Ah | 2.0 | 13.05 | 368 | 178 | 102 | 6.525 | 3.34 | 29.5 | 8s | Prismatic | NCM 811 | ||
| Jaguar | iPace | 2.5 | 12 | 340 | 155 | 112 | 4.8 | 2.4 | 10.8 | 720 | 1200 | 4p3s | Pouch | Li-ion |
| LG | 4P3S | 2.6 | 12.8 | 357 | 151 | 110 | 4.9 | 2.3 | 11 | 4p3s | Pouch | Li-ion | ||
| Mitsubishi | Outlander | 2.4 | 26 | 646 | 184 | 130 | 10.8 | 6.4 | 60 | 240 | 16s | Li-ion | ||
| MG ZS EV | (2021) 64.6Ah | 2.74 | 13.6 | 390 | 150 | 115 | 4.969 | 2.338 | 21.9 | 125 | 375 | 6s2p | Prismatic | NMC |
| Nissan | Leaf 24kWh | 0.5 | 3.65 | 300 | 222 | 34 | 7.3 | 4.5 | 7.2 | 130 | 228 | 2p2s | Pouch | Li-ion LMO |
| Nissan | Leaf 30kWh | 1.25 | 300 | 222 | 34 | 3.6 | 14.4 | 2p4s | Pouch | Li-ion | ||||
| Nissan | Leaf 40kWh | 1.6 | 8.7 | 300 | 222 | 68 | 5.4 | 2.8 | 14.4 | 314 | 2p4s | Pouch | Li-ion NMC | |
| Nissan | Leaf 62kWh | 2.58 | 14.4 | 3p4s | Li-ion | |||||||||
| Porsche | Taycan | 2.77 | 12.7 | 390 | 155 | 115 | 4.9 | 2.3 | 21.9 | 360 | 600 | 2p6s | Pouch | Li-ion |
| PSA/Opel | Peugeot E-208, Corsa E | 2.73 | 12.7 | 390 | 150 | 115 | 4.6 | 2.5 | 21.9 | 2p6s / 1p6s | Prismatic | Li-ion | ||
| Volvo | XC90 T8 | 2.01 | 12.1 | 300 | 180 | 150 | 6.0 | 4.0 | 59.2 | 170 | 340 | 16s | Li-ion | |
| VW | Passet GTE | 2.48 | 23.4 (with cooler plate)
10.8kg single |
410 (C/P)
355 (S) |
235 (C/P)
150 (S) |
150 (C/P)
108 (S) |
9.4 | 5.5 | 88.8 | 24s | Prismatic | Li-ion | ||
| VW | Golf GTE | 1.086 | 9.8 | 355 | 152 | 110 | 9.02 | 5.5 | 44 | 12s | Prismatic | Li-ion | ||
| VW | Touareg 14,1 kWh | 1.76 | 12.3 | 385 | 150 | 108 | 7.0 | 3.5 | 45.25 | 13s | Prismatic | Li-ion | ||
| VW | id3/id4 55kWh, 62kWh | 6.85 | 32 | 225 | 590 | 110 | 4.67 | 2.13 | 44.4 | 12s2p | ||||
| VW | id3/id4 82kWh | 6.85 | 32 | 225 | 590 | 110 | 4.67 | 2.13 | 29.6 | 8s3p | ||||
| Toyota | Prius Prime | 1.76 | 16.9 | 597 | 152 | 121 | 9.6 | 6.24 | 70.3 | |||||
| Renault | Kangoo | 3 | 16 | 310 | 210 | 140 | 5.3 | 3.03 | 29.6 | 8s | Li-ion |
- ↑ https://www.orionbms.com/manuals/pdf/parallel_strings.pdf (Backup: Web Archive)
- ↑ https://endless-sphere.com/forums/viewtopic.php?f=14&t=38761&start=900 (Backup: Web Archive)
- ↑ https://www.americanmicroinc.com/fish-paper/ (Backup: Web Archive)
- ↑ https://www.rogerscorp.com/elastomeric-material-solutions/poron-industrial-polyurethanes (Backup: Web Archive)
- ↑ 5.0 5.1 https://endless-sphere.com/forums/memberlist.php?mode=viewprofile&u=33107
- ↑ 6.0 6.1 https://endless-sphere.com/forums/viewtopic.php?f=14&t=38761 (Backup: Web Archive)
- ↑ https://earthshipbiotecture.com/a-lithium-ion-battery-primer/ (Backup: Web Archive)
- ↑ https://kokam.com/en/product/cell/lithium-ion-battery (Backup: Web Archive)
