Foccci
Foccci (v4.5) pinout
Foccci 4.5b / 5 / 5.1 pinout
Foccci on Github.
Clara on Github.
Pin description
Starting version 4.5b the pins were reshuffled to allow one wiring loom going to the charge port and one to the car side. Changed pins are bold.
TEMP2 A2 A2 As above
TEMP3 A3 A3 As Above
LOCK_MOT1 A9 A9
GND A12 B12
CANH B1 B1 CAN communication
CANL B2 B2
n.c. B4
GND B5 B5, B3
LED_RED B9 A12 Status LEDs
LED_GREEN B10 A11
LED_BLUE B11 A10
Internal connectors
short name description
UART RX Not used
Foccci with (Orion) BMS
  • EvseAcCurrentLimit
  • CableCurrentLimit
Wakeup
Here are the sources:
  4. CP - Edge triggered
Basic wakeup
  2. Wakeup signal is turned on
Advanced Wakeup
Semi-advanced wakeup
Configuring Foccci via CAN
Hardware Config
UdcDivider dig/V 0 100 10 Division factor from ADC digits to V of external voltage measurement board.
Communication
CanSpeed 0 4 2 Baud rate of CAN interface 0=125k, 1=250k, 2=500k, 3=800k, 4=1M - when configuring this != 500k you will loose communication to the ESP web interface!
Charge Parameters
ChargeCurrent A 0 500 0 Instantaneous current setpoint (volatile)
enable 0 1 1 When 0 charging is stopped/not started (volatile)
Testing
Spot values
Name Unit Description
version
lasterr Last detected error
cpuload
Errors
Error Description
CANTIMEOUT The ChargeCurrent hasn't been updated via CAN for more than 2s
  • Pin 1 - GND
The boostech BMS lacks one critical feature for rapid charging: a dynamic charge limit. That means ChargeCurrent it always a fixed value that you program into the BMS. It will not cut back when cells are getting full, hot or cold. It can be somewhat mitigated by setting a sane target voltage (e.g. 4.1V x NumberOfCells). The rapid charger will then start to cut back charge current as this voltage is approached. Also by mapping the enable flag the BMS has the possibility to abort the charging session if one single cell voltage rises above the safe threshold. In winter you will need to dial back your maximum charge current manually or heat you cells to avoid dendrites.
Hardware detection
- 47 2,7 0,179 222 216 229
- 47 3,3 0,217 269 261 277
- 47 3,9 0,253 314 304 323
- 47 4,7 0,300 372 361 383
- 47 5,1 0,323 401 389 413
- 47 5,6 0,351 436 423 449
- 47 6,8 0,417 518 502 533
- 47 7,5 0,454 564 547 580
- 47 9,1 0,535 664 644 684
4.2 47 10 0,579 718 697 740
4.3 47 12 0,671 833 808 858
4.4 47 15 0,798 991 961 1020
47 22 1,052 1306 1266 1345
47 27 1,204 1494 1449 1539
47 33 1,361 1689 1639 1740
47 39 1,497 1857 1801 1913
47 47 1,650 2048 1986 2109
47 56 1,794 2226 2160 2293
