Foccci
Revision as of 08:18, 25 June 2024 by Johu (talk | contribs) (Johu moved page Fully Open CCS Charge Controller (FOCCCI) to Foccci: title was wrong (controller instead of interface) anyway and this is shorter)
Foccci (v4.5) pinout
Foccci 4.5b pinout
Foccci on Github.
Pin description
Starting version 4.5b the pins were reshuffled to allow one wiring loom going to the charge port and one to the car side. Changed pins are bold.
Short name Pin up to 4.5a Pin from 4.5b Description
TEMP2 A2 A2 As above
TEMP3 A3 A3 As Above
LOCK_MOT1 A9 A9
GND A12 B12
CANH B1 B1 CAN communication
CANL B2 B2
n.c. B4
GND B5 B5, B3
LED_RED B9 A12 Status LEDs
LED_GREEN B10 A11
LED_BLUE B11 A10
Internal connectors
short name description
UART RX Not used
  • EvseAcCurrentLimit
  • CableCurrentLimit
Wakeup
For charging it is particularly interesting to wake up Foccci itself and necessary subsystems [1] when plugging in a charge cord. To allow for this, Foccci has various wakeup sources and also can wake up other devices. For wakeup to work, Foccci must be permanently supplied with 12V (it will draw no current when asleep).
Here are the sources:
  4. CP - Edge triggered
Basic wakeup
  2. Wakeup signal is turned on
Advanced Wakeup
Semi-advanced wakeup
Configuring Foccci via CAN
Hardware Config
UdcDivider dig/V 0 100 10 Division factor from ADC digits to V of external voltage measurement board.
ppvariant 0 9 0 Various circuit variations exist for PP resistor measurement. "1" is correct for the latest hardware (Foccci 4.2 and above) Technically, ppvariant=1 is the correct setting for Foccci with the PP circuit with 330 ohm pull-up to 5V and a 3k pull-down and a 47k by 47k divider.
WakeupPinFunc 0 4 0 Configure what the wakeup pin does. TODO: describe below
Communication
CanSpeed 0 4 2 Baud rate of CAN interface 0=125k, 1=250k, 2=500k, 3=800k, 4=1M - when configuring this != 500k you will loose communication to the ESP web interface!
Charge Parameters
ChargeCurrent A 0 500 0 Instantaneous current setpoint (volatile)
enable 0 1 1 When 0 charging is stopped/not started (volatile)
Testing
Spot values
Name Unit Description
version
lasterr Last detected error
StopReason
checkpoint
cpuload
Errors
Error Description
CANTIMEOUT The ChargeCurrent hasn't been updated via CAN for more than 2s
  • Pin 1 - GND
Can mapping boostech
The BMS sends out big endian messages hence why the length fields are negative. It does not send out a charge end voltage so we simply multiply the charge enable flag with the voltage we want. In the example 370V.
As of now this mapping is preliminary and has to be confirmed. will then remove this note
Hardware detection
- 47 2,7 0,179 222 216 229
- 47 3,3 0,217 269 261 277
- 47 3,9 0,253 314 304 323
- 47 4,7 0,300 372 361 383
- 47 5,1 0,323 401 389 413
- 47 5,6 0,351 436 423 449
- 47 6,8 0,417 518 502 533
- 47 7,5 0,454 564 547 580
- 47 9,1 0,535 664 644 684
4.2 47 10 0,579 718 697 740
4.3 47 12 0,671 833 808 858
4.4 47 15 0,798 991 961 1020
4.5 47 18 0,914 1134 1100 1168
47 22 1,052 1306 1266 1345
47 27 1,204 1494 1449 1539
47 33 1,361 1689 1639 1740
47 39 1,497 1857 1801 1913
47 47 1,650 2048 1986 2109
47 56 1,794 2226 2160 2293
