Tesla Model S/X DC/DC Converter
It is not to be confused with the earlier GEN1 DC-DC Converter, whose casing was of a kidney-shape, was located in the RF fenderwell against the firewall, and it incorporated functions of the front HVJB; it contains fuses for the coolant heater, cabin heater, and air-condition compressor, and servicing these fuses was never supported by Tesla (though is frequently performed in the aftermarket), so it developed a reputation for being unreliable due to frequent replacement for blown fuses. Though the hardware connections are different between GEN1 & GEN2, they both use the same (5) wired connections with the same functions, and the CAN commands appear to (may be) the same.
Wiring
HV
- Orange (A/C): MG655773 (key A)
- Gray (fluid heater): MG655774 (key B)
- Brown (PTC heater): MG655775 (key C)
- Blue (DC-DC): MG655776 (key D)
Donor Harness: Tesla OE/OEM Part Number: 1032804-00-A has two Blue DC-DC plugs.
LV & Signalling
LV connector (top row)
- Pin 1 : HW-EN (Enable ("turn on") via applying 12v+ )
- Pin 2 : CAN H
- Pin 3 : CAN L
Control
CAN
Two CAN MsgIDs are documented for this unit. When working with CAN, in some contexts, you need to know the hex (0x) or the decimal (0d) equivalent, eg DBC files and some CAN software requires 0d format, so both are given below:
- 0x03D8 (0d984) : Input: Commands to the unit (3 bytes)
- 0x0210 (0d528) : Output: Status Reporting from the unit (7 bytes)
Commands (0x03D8, 0d984)
This CAN command payload is 3 bytes, and must be sent at 500ms intervals.
- Byte 0 + Byte 1[0-1] (10 bits total) : (desired voltage - 9) * 146)
- Byte 1[2] = Enable DC output (must be 1 to enable output)
- Byte 1[3-7] : Unknown
- Byte 2 : Unknown
Example
If 14.4V is desired:
- Subtract constant 9 from 14.4v = 5.4
- Multiply 5.4 by constant 146 = 788.4
- Convert 788.4 to hex = 0x0315 (expressed as individual bytes: 0x03 0x15)
- Convert to little-endian format = 0x15 0x03
- Add 4 to the second byte, to enable DC output = 0x15 0x07
- Pad with zero byte to assemble the required 3-byte payload: 0x15 0x07 0x00
- Prefix with the command MsgID 0x3D8 : 0x03D8 0x15 0x07 0x00
- Send the MsgID + data payload
Status Reporting (0x0210, 0d528)
The data is comprised of 7 bytes, which is transmitted at 100ms (10Hz) intervals:
- Byte 2 = coolant inlet temp,
- Byte 3 = input power (16 W/bit),
- Byte 4 = output current (1 A/bit),
- Byte 5 / 10 = output voltage (0.1 V/bit)
Note Status Reporting does not work if HW-EN line is not high.
The "CAN3" above refers to the specific CAN bus on the early Tesla Model S, which had (5) (later, (6)) CAN buses. CAN3 is the Powertrain CAN bus.
SG_ Inlet_Temperature: 16|8@1- (0.5,40) [0|0] "C" TBD
SG_ Input_Power: 24|8@1+ (16,0) [0|0] "W" TBD
SG_ Output_Current: 32|8@1+ (1,0) [0|0] "A" TBD
SG_ Output_Voltage: 40|8@1+ (0.1,0) [0|0] "V" TBD
CM_ BO_ 528 "DC-DC Converter Status [10Hz]";
BO_ 528 DCDC_statusPartial: 2 ETH
SG_ DCDC_outputCurrent: 0|8@1+ (1,0) [0|0] "A" X
SG_ DCDC_outputVoltage: 8|8@1+ (0.1,0) [0|0] "V" X
- ↑ https://openinverter.org/forum/viewtopic.php?p=20995#p20995
- ↑ https://skie.net/uploads/TeslaCAN/Tesla%20Model%20S%20CAN%20Deciphering%20-%20v0.1%20-%20by%20wk057.pdf
- ↑ https://brianman.visualstudio.com/DBCTools/_git/DBCTools?path=/Samples/tesla_models_rwd.dbc&version=GBmaster
- ↑ https://brianman.visualstudio.com/DBCTools/_git/DBCTools?path=%2FSamples%2Ftesla_models.dbc&version=GBmaster
