Tesla Model S/X DC/DC Converter
Revision as of 00:28, 1 April 2023 by Asavage (talk | contribs) (Example: Added a bit of color to the hex examples, to highlight the line-to-line transformation differences.)
It is not to be confused with the earlier GEN1 DC-DC Converter, whose casing was of a kidney-shape, was located in the RF fenderwell against the firewall, and it incorporated functions of the front HVJB; it contains fuses for the coolant heater, cabin heater, and air-condition compressor, and servicing these fuses was never supported by Tesla (though is frequently performed in the aftermarket), so it developed a reputation for being unreliable due to frequent replacement for blown fuses. Though the hardware connections are different between GEN1 & GEN2, they both use the same (5) wired connections with the same functions, and the CAN commands appear to (may be) the same.
Tesla Model S GEN2 DC-DC Converter
Wiring
HV
Minimum required wiring for basic unit function: Seven wires from left):(2) HV Input, (1) HW Enable, (2) CAN (if voltage control is needed), (3) 12VDC Output
CAN lines are pins 2 & 3.
  • Orange (A/C): MG655773 (key A)
  • Gray (fluid heater): MG655774 (key B)
  • Brown (PTC heater): MG655775 (key C)
  • Blue (DC-DC): MG655776 (key D)
Donor Harness: Tesla OE/OEM Part Number: 1032804-00-A has two Blue DC-DC plugs.
Pinout for LV connector is written on the board
Pinout for LV connector is printed on the board.
LV & Signalling
LV connector (top row)
  • Pin 1 : HW-EN (Enable ("turn on") via applying 12v+ )
  • Pin 2 : CAN H
  • Pin 3 : CAN L
Control
CAN
Two CAN MsgIDs are documented for this unit:
  • 0x03D8 : Input: Commands to the unit (3 bytes)
  • 0x0210 : Output: Status Reporting from the unit (7 bytes)
Commands (0x03D8)
This CAN command payload is 3 bytes, and must be sent at 500ms intervals.
  • Byte 0 + Byte 1[0-1] (10 bits total) : (desired voltage - 9) * 146)
  • Byte 1[2] = Enable DC output (must be 1 to enable output)
  • Byte 1[3-7] : Unknown
  • Byte 2 : Unknown
Example
If 14.4V is desired:
  • Subtract constant 9 from 14.4v = 5.4
  • Multiply 5.4 by constant 146 = 788.4
  • Convert 788.4 to hex = 0x0315 (expressed as individual bytes: 0x03 0x15)
  • Convert to little-endian format = 0x15 0x03
  • Add 4 to the second byte, to enable DC output = 0x15 0x07
  • Pad with zero byte to assemble the required 3-byte payload: 0x15 0x07 0x00
  • Prefix with the command MsgID 0x3D8 : 0x03D8 0x15 0x07 0x00
  • Send the MsgID + data payload
Status Reporting (0x0210)
The data is comprised of 7 bytes, which is transmitted at 100ms (10Hz) intervals:
  • Byte 2 = coolant inlet temp,
  • Byte 3 = input power (16 W/bit),
  • Byte 4 = output current (1 A/bit),
  • Byte 5 / 10 = output voltage (0.1 V/bit)
Note Status Reporting does not work if HW-EN line is not high.
Tesla Model S DC-DC Converter CAN information by Jason Hughes, (wk057), Jan2016.
The "CAN3" above refers to the specific CAN bus on the early Tesla Model S, which had (5) (later, (6)) CAN buses. CAN3 is the Powertrain CAN bus.
