Tesla Model S GEN1 Charger
The Tesla GEN1 on-board AC charger (OBC) is a single/three phase 10kW AC charger that was fitted originally and primarily in the Tesla Model S, from 2012 through late 2013, when it was replaced with GEN2. GEN1 models are easy to identify, having the word "TESLA" stamped on the top metalwork and no anti-tamper tape; the GEN2 charger lacks the Tesla identifier stamped on the metalwork, and has anti-tamper tape over the seams.
The GEN1 chargers are considered to be more trouble-prone than the later units, and are not as popular for use in EV conversions or ground-up builds, but are used in many OEM installations that continue to need servicing. Examples of OEM installs include the 2012-13 Tesla Model S, 2012-14 Toyota RAV4 EV[1], and 2014-17 MB B250e[2]. As far as is known, these are identical from a hardware perspective[3], but the firmware does differ and is not interchangeable between installations.
Connectors
Charger Connections
Logic Connector X042
The Logic Connector X042 needed to plug into the charger is Molex 19418-0026[4] which is in the MX150L series. This connector features CPA[5] (Connector Position Assurance), a dual-locking feature. For bench-testing, etc., the non-CPA connector is Molex 19418-0038[6]; this connector requires one less operation to disengage, but is less suitable for automotive use or environments where heavy vibration is present.
Pin No. | Function | Description | Wire size * | Wire Color * |
6 | FC CAN (SWCAN?) | 20 AWG (0.5mm²) | RD-WH | |
12 | "BMS_12V_in" | (BMS enables charger?) | 18 AWG (0.75mm²) | RD-GY |
Input/Output Connectors
AC (Input) Connector Xnnn
DC (Output) Connector Xnnn
Unknown Connector Xnnn
Common Issues
- Fuses
The two 50A fuses (AC? DC?) are commonly found to fail. The cause is not known. Some units have their fuses fail more than once. There are two, and typically only one fails at a time. The fuses are special high-speed units for use with sensitive electronics. Ferraz Shawmut 50A 500VAC fuse, part No. A50P50-4[11]. Some people have found that after replacing a single failed fuse, the other one will later fail, so the generic recommendation is to replace them both. Typical pricing is USD$50-100 each in 2023.
Charger Dimensions:
- nnnmm x nnnmm x nnnmm
- Weight: nn lbs (nn kg)
Tesla Part Numbers (TPN):
- 6009278-00-x
- 6009278-84-x (ReManufactured?)
- 6009354-00-x
Toyota Part Numbers:
- G9090-0R010 (discontinued)
- G9090-0R011
MB Part Number(s):
- TBD
