Tesla Model S GEN1 Charger
Connectors
Charger Connections
Logic Connector X042
The Logic Connector X042 needed to plug into the charger is Molex 19418-0026[3] which is in the MX150L series.
The female terminals for this housing are Molex 19420-0010[4]
| Pin No. | Function | Description | Wire size (Tesla Model S) |
| 1 | 12v supply | 18 AWG (0.75mm²) | |
| 2 | Charge Port: nozzle lock | "InsertEN out" | 20 AWG (0.5mm²) |
| 3 | HVIL Out | 20 AWG (0.5mm²) | |
| 4 | CAN + | 20 AWG (0.5mm²) | |
| 5 | EVSE-Pilot (CP) | 20 AWG (0.5mm²) | |
| 6 | FC CAN (SWCAN?) | 20 AWG (0.5mm²) | |
| 7 | 12v GND | 20 AWG (0.5mm²) | |
| 8 | Drive inhibit | "Prox out", signal to DU to inhibit drive | 22 AWG (0.35mm²) |
| 9 | HVIL In | 20 AWG (0.5mm²) | |
| 10 | CAN - | 20 AWG (0.5mm²) | |
| 11 | EVSE-Prox (PP) | 20 AWG (0.5mm²) | |
| 12 | "BMS_12V_in" | (BMS enables charger?) | 18 AWG (0.75mm²) |
Input/Output Connectors
AC (Input) Connector Xnnn
The AC Input Connector housing needed to plug into the charger is Molex 42816-0412[5]
The female terminals for this housing are Molex 42815-0134[6] for 8 AWG (8mm²).
DC (Output) Connector Xnnn
The DC Output Connector housing needed to plug into the charger is Molex 42816-0312[7]
Unknown Connector Xnnn
Common Issues
Charger Dimensions:
- nnnmm x nnnmm x nnnmm
- Weight: nn lbs (nn kg)
Tesla Part Numbers (TPN)
- 6009278-00-x
