Tesla Model S GEN1 Charger
Revision as of 18:36, 25 February 2023 by Asavage (talk | contribs) (Connectors)
Tesla GEN1 Onboard AC Charger
Connectors
Charger Connections
Logic Connector X042
The Logic Connector X042 needed to plug into the charger is Molex 19418-0026[3] which is in the MX150L series.
Molex 194180026, female connector to mate with X042 Logic Connector on Tesla GEN1 OBC.
The female terminals for this housing are Molex 19420-0010[4]
Logic Connector X042, 12-pin
Pin No. Function Description Wire size (Tesla Model S)
1 12v supply
2 Charge Port: nozzle lock "InsertEN out"
3 HVIL Out 20 AWG (0.5mm²)
4 CAN + 20 AWG (0.5mm²)
5 EVSE-Pilot (CP) 20 AWG (0.5mm²)
6 FC CAN (SWCAN?) 20 AWG (0.5mm²)
7 12v GND 20 AWG (0.5mm²)
8 Drive inhibit "Prox out", signal to DU to inhibit drive 22 AWG (0.35mm²)
9 HVIL In 20 AWG (0.5mm²)
10 CAN - 20 AWG (0.5mm²)
11 EVSE-Prox (PP) 20 AWG (0.5mm²)
12 "BMS_12V_in" (BMS enables charger?) 18 AWG (0.75mm²)
Input/Output Connectors
Tesla Model S GEN1 OBC Power Connectors
AC (Input) Connector Xnnn
The AC Input Connector housing needed to plug into the charger is Molex 42816-0412[5]
The female terminals for this housing are Molex 42815-0134[6] for 8 AWG (8mm²).
DC (Output) Connector Xnnn
The DC Output Connector housing needed to plug into the charger is Molex 42816-0312[7]
Unknown Connector Xnnn
Common Issues
Charger Dimensions:
  • nnnmm x nnnmm x nnnmm
  • Weight: nn lbs (nn kg)
Tesla Part Numbers (TPN)
  • 6009278-00-x
