EV Conversion Parts
Motors
AC Induction Motors
- Siemens 1PV5135-4WS14
PMSM (Permanent Magnet Synchronous Motors)
These Requires FOC Firmware.
- Nissan Leaf EM57 (Gen 2)
- Nissan Leaf EM61 (Gen 1)
- Remy HVH-250
There is a more general Motor List as well.
Batteries
CALB
LG Chem - BMW Hybrid
LG Chem - BMW I3
LG Chem - Chevy Volt
LG Chem - Chrysler Pacifica Hybrid
Tesla
Brakes
Vacuum Boosted
Vacuum Pumps
Vacuum pumps are available via several OEM and 3rd party manufacturers. Some options may include:
- Leed Brakes Bandit series (apparently runs quiet)
- Aeroflow Performance Twin Piston Vacuum Pump Kit
Vacuum Sensors:
- BOSCH 0 265 005 331 / 13581083
- Pin 3 - 5V
- Pin 2 - Gnd
- Pin 1 - Value - 0.48v under no vacuum
- Seems to have checkvalve built in.
Electrically Boosted:
There are a couple of options for electrically boosted braking systems, with one of the most popular being the Bosch iBooster.
More info on using the iBooster is available here, and pinouts for the Tesla versions here
iBooster gen1 connectors:
Main connector (26-pin): Bosch "EuCon" 26p
- Main housing: 1928405762
- Cover: 1928405765
- Pins: Bosch BTC Terminal
- 1928498807 - BTC 4.8 / Terminal Sn / > 2.5 - 4 mm² (main power: pins 1 & 9)
- 1928498806 - BTC 2.8 / Terminal Sn / 1.5 - 2.5 mm² (constant power: pin 17)
- 1928498705 - BTC 1.5 / Terminal Sn / 0.35 - 0.5 mm² (ignition power: pin 20; signal pins 2, 8, 22, 23)
- Seals: Bosch BTC
- 1928301086 - BTC 4.8 / Seal / Blue (∅ 3.4 - ∅ 3.7 mm²)
- 1928301206 - BTC 2.8 / Seal / Reddish Brown (∅ 2.0 - ∅ 2.7 mm²)
- 1928301083 - BTC 1.5 / Seal / Grey (∅ 1.6 - ∅ 1.9 mm²)
- Plugs: Bosch BTC
- 1928301207 - BTC 2.8 / Plug / Green
- 1928301087 - BTC 1.5 / Plug / White
Sensor connector (4-pin): TE MQS
- Housing: 1-967640-1
- Pins: 5-965906-5 (20 - 18 AWG)
- Seals: 1-967067-1 (∅ 1.4 - ∅ 2.1 mm²)
iBooster Sourcing
| Part Number | Generation | Models available in |
| 5QE614105AH | Volkswagen e-Golf (2016-2018)
Audi A3 Sportback e-tron (2017) | |
| 5QE614105AK | Gen 1 | Volkswagen e-Golf (2016-2018)
Volkswagen Passat GTE (2017) Volkswagen Golf GTE (2017) |
| 5QE614105AN | Gen 2 | Volkswagen e-Golf (2018-2019) |
| 5QE614105AQ | Gen 2 | Volkswagen e-Golf (2018-2019) |
| 5QE614105S | Volkswagen e-Golf (2016-2018)
| 1037123-00-A | Gen 1 | Tesla Model S
Tesla Model X |
| 1037123-00-B | Gen 1 | Tesla Model S
Tesla Model X |
| 1044671-00-D | Tesla Model 3 | |
| 1044671-00-E | Gen 2 | Tesla Model 3 |
An alternative list (mostly the same) of iBooster donors can be found here: https://www.evcreate.nl/ibooster-donor-vehicles/
Charger
Built-In
Chevy Volt / Lear
Tesla Gen 2 10kW(?)
Tesla PCS
Contactors
EV Conversion Parts - Contactors - Panasonic AEV14012
DC/DC
Chevy Volt / Lear
Prius Inverters
tesla model s
High Voltage Junction Box
Building a junction box
