Toyota Prius Gen3 Board
Prius Inverter
Control Board
Development History
Vendors
Support
Inverter Model Numbers
| G9200-47141 | Auris 2012, RHD | ||||||
| G9200-47190 | Auris | F1759-52010 04 | ? | Forum Thread openinverter.com | |||
| G9200-52010 | Yaris | F1759-52010 04 | F1789-52010 | 154x143mm | https://openinverter.org/forum/viewtopic.php?f=14&t=257&p=5828#p5828 | ||
| G9201-52012 | Prius C | F1759-52010 | F1789-52010 | YES (presumably) | Forum Thread openinverter.com |
Soldering The Breakout Board
Soldering the Main Board
And Conn8, again easy.
[add photo]
Powering up
Checking voltages
Check for ~3.3v here on C32
Finally the 26v
Firmware
Wifi Module Firmware
Programming Firmware
For Windows
Atmega328p Firmware
Inverter Parameters
| pwmfrq | ||
| deadtime | 130 | |
| minpulse | ||
| il1gain | ||
| il2gain | ||
| udcgain | ||
| udcofs | ||
| udclim | ||
| snshs | ||
| pinswap | PWMOutput23 |
First Run (PWM verify)
Navigate to the Web Interface
Stop the inverter
DC-DC Converter
12v Battery Connection
Motor Connection
IDC Connector
Connections are as follows:
| 23 | MG2_STATOR_T1 | 5V analogue input from motor temperature sensor. These are typically variable resistance devices. Connect the other side of the sensor to +5V. |
| 24 | MG2_STATOR_T2 | 5V analogue input from motor temperature sensor. These are typically variable resistance devices. Connect the other side of the sensor to +5V. |
| 25 | MAIN_CON | 5V output to switch main HV contactor. Note that you cannot switch these 12V devices directly from this output. You will need either a transistor or smaller relay arrangement to provide the appropriate voltage/current. |
| 26 | PRECHG_RLY | 5V output to switch the pre-charge relay. Note you cannot switch these 12V devices directly from this output. You will need either a transistor or smaller relay arrangement to provide the appropriate voltage/current. |
| 27 | AC_CON | 5V output to switch the main charger AC input relay. Note you cannot switch these 12V devices directly from this output. You will need either a transistor or smaller relay arrangement to provide the appropriate voltage/current. |
| 28 | HV_CON | ? |
| 29 | AC_PRECH | 5V output to switch the charger AC input pre-charge relay. Note you cannot switch these 12V devices directly from this output. You will need either a transistor or smaller relay arrangement to provide the appropriate voltage/current. |
| 31 | EVSE_PROX | |
| 32 | CONTROL_PILOT | |
Ampseal Socket & Plug
| 22 | MOTOR TEMP SENSOR A | 5V analogue input from motor temperature sensor. These are typically variable resistance devices. Connect the other side of the sensor to +5V. |
| 23 | MOTOR TEMP SENSOR B | 5V analogue input from motor temperature sensor. These are typically variable resistance devices. Connect the other side of the sensor to +5V. |
| 24 | MAIN HV CONTACTOR | 5V output to switch main HV contactor. Note that you cannot switch these 12V devices directly from this output. You will need either a transistor or smaller relay arrangement to provide the appropriate voltage/current. |
| 25 | HV PRECHARGE RELAY | 5V output to switch the pre-charge relay. Note you cannot switch these 12V devices directly from this output. You will need either a transistor or smaller relay arrangement to provide the appropriate voltage/current. |
| 26 | CHARGER AC INPUT RELAY | 5V output to switch the main charger AC input relay. Note you cannot switch these 12V devices directly from this output. You will need either a transistor or smaller relay arrangement to provide the appropriate voltage/current. |
| 28 | CHARGER AC PRECHARGE RELAY | 5V output to switch the charger AC input pre-charge relay. Note you cannot switch these 12V devices directly from this output. You will need either a transistor or smaller relay arrangement to provide the appropriate voltage/current. |
| 34 | NOT USED | |
| 35 | NOT USED |
Connecting Resolver
Bill of Materials (Github)
