Leaf stack with zombiverter
The full leaf stack ( motor/inverter, pdm (charger, dcdc, hvjb)) can be controlled with the zombieverter VCU.
All you need is 12v+, enable, and CANbus.
Wiring
Wiring the zombiverter to the leaf harness
Description Zombieverter Pin PDM pin inverter pin
+12V Permanent 12v+ 56 18 46, 48
Gnd permanent 12v - 55 pdm case 47, 49
Fwd signal Forward 54
Rev signal Reverse 53
momentary 12V Start signal 52
Brake signal Brake Input 49
+5V Throttle 48
Throttle signal 1 Throttle signal 1 47
Throttle signal 2 Throttle signal 2 46
Throttle Gnd Throttle Gnd 45
Precharge Contactor LS Switch Negative lead from precharge contactor 34
Main Contactor LS Switch Negative lead from main contactor 33
enable relay switches enable relay 32 16 42
Neg Contactor LS Switch Negative lead from negative contactor 31
CANEXTH Can 1 High 28 27 14
CANEXTL Can 1 Low 27 11 15
T15 Ignition 12V in 15
proximity pilot pp for charge port 29
control pilot cp for charge port 30
leaf inverter connector
Chademo to Zombiverter:
chademo connector:
HV contactor coil - pin 10
pin 1 to ground
CAN H pin 8 to CAN EXT 3 H
CAN L pin 9 to CAN EXT 3 L
pin 4 to GP out 3
