Leaf stack with zombiverter
The full leaf stack ( motor/inverter, pdm (charger, dcdc, hvjb)) can be controlled with the zombieverter VCU.
All you need is 12v and CANbus.
Wiring
Wiring the zombiverter to the leaf harness
INVERTER to zombie wiring:
EV SYSTEM CAN-H (pin14) to CAN EXT H (pin 28)
EV SYSTEM CAN-L (pin15) to CAN EXT L (pin 27)
PDM to zombie wiring:
CAN H (ev system) pin 27 to CAN EXT H (pin 28)
CAN L (ev system) pin 11 to CAN EXT L (pin27)
EVSE CONNECTING SIGNAL pin 29 to
EVSE COMMUNICATION (PWM) pin 30 to
Chademo to Zombiverter:
chademo connector:
HV contactor coil - pin 10
pin 1 to ground
CAN H pin 8 to CAN EXT 3 H
CAN L pin 9 to CAN EXT 3 L
pin 4 to GP out 3
control:
n.b to be checked with regards to pinouts above
Description | Zombieverter Pin | |
+12V | Permanent live | 56 |
Gnd | Ground | 55 |
Fwd signal | Forward | 54 |
Rev signal | Reverse | 53 |
momentary 12V | Start signal | 52 |
Brake signal | Brake Input | 49 |
+5V | Throttle | 48 |
Throttle signal 1 | Throttle signal 1 | 47 |
Throttle signal 2 | Throttle signal 2 | 46 |
Throttle Gnd | Throttle Gnd | 45 |
CANEXT2H | CAN 2 High (ISA Shunt) | 44 |
CANEXT2L | Can 2 Low (ISA Shunt) | 43 |
Precharge Contactor LS Switch | Negative of low side precharge contactor | 34 |
Main Contactor LS Switch | Negative of low side main contactor | 33 |
Inv power switch | Relay negative coil to turn on inverter/PDM | 32 |
Neg Contactor LS Switch | Negative of low side negative contactor | 31 |
CANEXTH | Can 1 High | 28 |
CANEXTL | Can 1 High | 27 |
T15 | Ignition 12V in | 15 |
