Lexus GS450h Drivetrain
- Two high power inverters, for the 2 motors MG1 capable of handling X(?) amps, and MG2 capable of handling Y(?) amps.
Weight: 40 lbs
Buck/Boost Converter
Transmission
For technical analysis of this transmission, see pages 46 and onward of this document: https://www.osti.gov/servlets/purl/947393
- Oil Pump
Overview and location
Wiring and control
The external pump also requires a controller. Although this is rarely included with the transmission, it's quite affordably and widely available (Toyota part number: G1167-30020)
Pinouts, schematics and notes
- Brown (pin 7) is feedback from the oil pump. It's PWM. Do what you want with this or leave it disconnected.
Gasket (1) 35142-30010 $14
Wiring Harness Connectors
Inverter Connectors
OEM
90980–12630 |
Black connector on the side of the inverter. This connector is not sold anywhere to our knowledge. |
Alternatives
Molex MX123 series
Assembly Instructions
Instructions on how to assemble the MX123 connector can be found here: MX123 Connection System User Manual
Transmission Connectors
Control Schemes
ZombieVerter VCU
Lexus GS450h VCU (deprecated)
An open-source VCU, designed by Damien Maguire, can be purchased as a partially populated board on his website:
A full schematic for the system can be found at this link
Note that in addition to the VCU, inverter and transmission, a specific CAN bus connected shunt (ISA shunt) is required: Isabellenhütte Heusler
- 33472-2002 (Left side, grey in colour)
- 33472-2001 (Right side, black in colour)
- 33012-2002 (Crimp terminals)
- 5810130065 (Enclosure)
- 5810140011 (Header, 40 Pos.)
- 75867-101LF (CONN1, Header for Wi-Fi module)
- 5787834-1 (CONN2, USB 2.0 receptacle)
- TR10S05 (IC10, 5V DC/DC converter)
VCU Firmware
This guide relates to V3.01 available here on Github : https://github.com/damienmaguire/Lexus-GS450H-Inverter-Controller/blob/master/Software/gs450h_v3_user.ino
A video tutorial to accompany this guide and firmware is available here :https://vimeo.com/501777258
Instructions for use
Once connected, type ? and press enter. The following menu should then display :
? - Print this menu
D - Print configuration data
f - Calibrate minimum throttle.
g - Calibrate maximum throttle.
i - Set max drive torque (0-3500) e.g. typing i200 followed by enter sets max drive torque to 200
q - Set max reverse torque (0-3500) e.g. typing q200 followed by enter sets max reverse torque to 200
v - Set gearbox oil pump speed (0-100%) e.g. typing v50 followed by enter sets oil pump to 50% speed
a - Select LOW gear.
s - Select HIGH gear.
z - Save configuration data to EEPROM memory
? Will display the menu.
d Displays data from the inverter in this format :
0 1 2 3 4 5 6 7 8 9
00 | 0 0
10 | 0 0 0 0 0 0 0 0
20 | 0 0 0 0 0 0 0 0 0 0
30 | 0 0 0 0 0 0
40 | 0 0 0 0 0 0 0 0
50 | 0 0 0 0 0
60 |
70 |
80 | 0 0 0 0 0 0
90 | 0 0 0 0 0 0 0 0
MTH Valid: Yes Checksum: 0
DC Bus: ----v
MG1 - Speed: 0rpm Position: 0
MG2 - Speed: 0rpm Position: 0
Water Temp: 0.00c
Inductor Temp: 0.00c
Another Temp: 0c
Another Temp: 0c
D (capital or large D) displays VCU configuration data as well as information on the Gearbox status in this format :
Throttle Channel 1: 109
Throttle Channel 2: 53
Commanded Torque: 0
Selected Direction: DRIVE
Selected Gear: HIGH
Current valve positions:
PB1:ON
PB2:ON
PB3:ON
MG1 Stator temp: 109.69
MG2 Stator temp: 109.69
Throttle calibration procedure :
First, drive torque:
Configured drive torque: 500
Now reverse torque:
Parameters stored to EEPROM
An option is provided to set the speed in % (0 to 100%) for the electric gearbox oil pump. In this example we set the speed to 50% :
I have found in testing on the E65 that 50% is a good value for keeping oil pressure up , providing cooling etc. without running the pump too hard. Your millage may vary.
LOW Gear Selected
HIGH Gear Selected
Selecting Direction.
The firmware supports the use of the IN1 and IN2 pins of the V2 VCU as direction control inputs. Operation is as follows :
Wi-Fi Display
Once powered, the Wi-Fi module will create an open access point with an SSID like ESP-XXXX where XXXX will be a series of letters and numbers.
Connect to this access point with any Wi-Fi enabled device (e.g. laptop, tablet, phone etc.).
You may wish to change the SSID and add a passphrase to the access point. To do this goto : 192.168.4.1/admin
A simple set of dialog boxes will allow the SSID, passphrase and background colour of the gauge display to be set.
Development History
Vendors
EVBMW: https://www.evbmw.com/index.php/evbmw-webshop/vcu-boards/gs450h-vcu
NOTE: There are currently no vendors who offer support on any aspects of the GS450h VCU.
Support
