ZombieVerter VCU
Revision as of 17:01, 24 October 2021 by Jack Bauer (talk | contribs)
What we have as of now is the openinverter wrapper with things like :
  • Throttle cal and mapping,
  • Precharge and contactor control,
  • Temp derating,
  • BMS limits,
  • for/rev/neutral control,
  • Graphing and monitoring,
  • Firmware updates via the web interface,
  • Cruise control,
  • Fuel gauge driver,
  • etc
So you've ordered your kit, first things first, watch the following video to assemble it.
Due to chip shortages (written summer 2021) the board isn't fully assembled so you will need to do some soldering, or take it to a local phone repair shop (or similar) who'll find soldering at this scale like playing with Duplo.
The enclosure kit links:
Enclosure Kit with Header, connector and pins :
Prewired connector with 3M leads :
https://youtu.be/MUhs9j9R9Mg
Note that in addition to the VCU, the inverter and transmission, you will require a specific canbus connected shunt: Isabellenhütte Heusler
Wiring information for the system, connector pinouts etc can be found here: Lexus GS450h Inverter
Pin Out Diagram
VCU pinout diagram
List of connections to system components
Software
Then navigate to 192.168.1.4 to see the huebner inverter dashboard.
Supported OEM Hardware
  • Nissan Leaf Gen1/2/3 Inverter/ motor
  • nissan leaf gen 2 drive stack (inverter, dcdc, charger) gen 3 coming soon
