Tesla Model S/X GEN2 Charger
The Tesla GEN2 charger is a single/three phase 10kW AC charger that was fitted in the Model S from 2012 until it was replaced in the 2016 'facelift' model with GEN3.
One or two GEN2 chargers are installed beneath the rear seats in the model s for ac charging.
The charger is made up of three 3.3 kw modules, each sitting on a liquid cooling plate. This assembly enables both single and multi phase ac charging.
Replacement control boards
replacement control board https://github.com/damienmaguire/Tesla-Charger
Charger connection
| A1 | A2 | A3 | A4 | A5 | B1 | B2 | B3 | B4 | B5 | B6 | |
| OUT2 - AC present | D1 - enable | 12V supply | CANH | Control Pilot | |||||||
| A6 | A7 | A9 | A10 | A11 | B7 | B8 | B9 | B10 | B11 | B12 | |
| OUT1 - HV enable | GND | CANL | Proximity |
Connector part numbers
AC and DC power connections - housing 044441-2006, pins 0433753001
Logic connectors Molex: housing 10 way 19418-0014, 12 way 19418-0026, pins 33012-2001
Programing
you'll need a st-link v2 smt32 programmer. Unofficial ones are cheaply available from amazon and ebay.
st-link programming utility: https://www.st.com/en/development-tools/stsw-link004.html
stm32_loader.hex https://openinverter.org/forum/viewtopic.php?f=7&t=1119
Two options:
- Charger_gen2_v5.hex https://github.com/damienmaguire/Tesla-Charger/tree/master/V5/Software/Binary
- Or commercial software: https://openinverter.org/files/stm32_charger.zip
This will ask to open a file, you choose: "stm32_loader.hex" from OpenInverter.org, download ahead of time. This will change what shows up in the viewing window.
Future updates can be done via wifi. (must have esp8266 wifi module programed https://openinverter.org/forum/viewtopic.php?f=5&t=8 )
External CAN bus
The V5aB2 version of the board has no connection to the external CAN bus (V5aB3 has) but you can add it with to bodge wires as shown in the picture. You will find CANH and CANL on the 3 pin header underneath the wifi module. Route them over to CONN6 as shown. CONN2.1 (CANH) is connected to CONN6.24, CONN2.2 (CANL) to CONN6.26.
Revision V4aB3 does not need this modification. If you do NOT use the external CAN bus on that version remember to close the solder jumper next to R1 under the Wifi module.
If the charger is the first/last device on your CAN bus there is nothing else to do. If it is somewhere in the middle you have to remove the bus termination resistor R1.
Before doing this be aware that all internal CAN traffic is also seen on the external CAN bus. The following IDs are already used and mustn't used by any other device on the bus:
207, 209, 217, 219, 227, 229, 237, 239, 247, 249, 327, 329, 347, 349, 357, 359, 367, 368, 369, 377, 379, 537, 539, 717, 719, 20B, 21B, 22B, 23B, 24B, 32B, 34B, 35B, 36B, 37B, 42C, 43C, 44C, 45C, 53B, 71B.
| ID | Direction | Byte 0 | Byte 1 | Byte 2 | Byte 3 | Byte 4 | Byte 5 | Byte 6 | Byte 7 |
| 0x102 | Receive by charger | DC voltage limit MSB | DC voltage limit LSB | DC current set point | ==1 enable charging | SoC | |||
| 0x108 | Transmit by charger | Version=0 | Max DC voltage MSB | Max DC voltage LSB | Max DC current | ||||
| 0x109 | Transmit by charger | Version=0 | DC voltage MSB | DC voltage LSB | DC current | 0 when off, 5 when charging
Doesn't belong here, will move to Byte 5 after 1.06.R! |
Like Byte 4
for versions after 1.06.R |
Example: transmit "0x102 # 0 0x1 0x86 0x14 0x1 50 0 0" to enable charging up to a voltage of 390V and a DC current of 20A, report SoC of 50%.
Commercial charger firmware
In addition to the open source firmware there is also a commercial firmware. It adds advanced features:
- Support for the standard open inverter web interface
- Parameter handling as known from the inverter firmware (see picture)
- Spot value handling like inverter including plotting, gauges, and logging
- Over the air update like inverter
- DC current control
- CAN control as described above
By default you can connect to the network (Acces Point) and browse to: 192.168.4.1
By default all charger kits will have SSID : charger PASSWORD : charger123
Note: Its recommend that you change it. No body wants to drive and have some joker with a phone finding this information and accesing your charger.
Registration
The firmware will work without registration but charging time is limited to 5 minutes. To overcome this, a board-specific pin must be bought. In order to do this the firmware and web interface must be installed and working.
Go to the openinverter webshop and check out as many pins as you need. When checking out add the serial number(s) of your board(s) in the order option. You will find the serial number on the bottom of the page as last spot value.
You will then receive an email containing one pin for each board. Enter the pin in the web interface in the "pin" parameter. When the pin is correct it will be automatically saved to flash and your board is ready to be used.
Commercial firmware usage manual
We will go over all of them.
idclim
iaclim
idcspnt
chargerena
udcspnt
udclim
timelim
inputype
- Type2: Specifies one or more modules are operated on ONE common phase of a Type-2 EVSE. The limits imposed by cablelim and evselim (pilot signal) are distributed equally over the enabled modules. For example if you enable all 3 modules, the cable allows 32A but the EVSE only allows 16A, every module will run at 16/3=5.3A. Charging will start automatically as soon as proximity and a valid pilot signal is detected.
- Type2-3P: Specifies each module is connected to a different phase of a Type-2 EVSE. The limits imposed by cablelim and evselim are allowed for each module.
- Type1: Like Type2 but cablelim is always assumed 40A.
- Manual: Specifies one or more modules are operated on ONE common phase, power is distributed like in Type2 mode. Charging starts as soon as the enable pin "D1" goes high. iaclim MUST be configured to the limits of your AC source as there is no automatic detection like in Type1 or Type2 modes.
- Manual-3P: Specifies that each module is connected to a different phase of 3-phase outlet. Each module is allowed iaclim AC current. iaclim MUST be configured to the limits of your AC source as there is no automatic detection like in Type1 or Type2 modes.
cancontrol
idckp/idcki
pin
