Toyota Prius Gen3 Board
Prius Inverter
Control Board
Development History
Vendors
Support
Inverter Model Numbers
G9200-47190 | Auris | F1759-52010 04 | ? | Forum Thread openinverter.com | |||
G9200-52010 | Yaris
Prius C |
G9200-52031 | Yaris 2016 | F1759-52010 04 | F1789-52010 | YES | YES | ||
G9201-52012 | Prius C | F1759-52010 | F1789-52010 | YES (presumably) | Forum Thread openinverter.com | ||
G9200-52030 | Prius C (a.k.a. Prius Aqua) | F1759-52010 04 | F1789-52010 | 154mm long | Forum Thread openinverter.com |
Soldering The Breakout Board
Soldering the Main Board
And Conn8, again easy.
[add photo]
Powering up
Checking voltages
Check for ~3.3v here on C32
Finally the 26v
Firmware
Wifi Module Firmware
- Write code to ESP8266
- Write filesystem to ESP8266
Programming Firmware
For Windows
Atmega328p Firmware
Inverter Parameters
Parameter | Suggested Value | Notes |
pwmfrq | 2 | PWM frequency. 0=17.6kHz, 1=8.8kHz, 2=4.4kHz, 3=2.2kHz. Needs PWM restart |
pwmpol | 0 - Active High | DO NOT PLAY WITH THIS! |
deadtime | 130 | Deadtime between highside and lowside pulse. 28=800ns, 56=1.5µs. Not always linear, consult STM32 manual. Needs PWM restart |
il1gain | 4.56 | Digits per A of current sensor L1 |
il2gain | 4.5 | Digits per A of current sensor L2 |
udcgain | 5 | Digits per V of DC link |
udcofs | 0 | DC link 0V offset |
udclim | 540 | High voltage at which the PWM is shut down |
snshs | 1 | Heatsink temperature sensor. 0=JCurve, 1=Semikron, 2=MBB600, 3=KTY81, 4=PT1000, 5=NTCK45+2k2, 6=Leaf |
pinswap | 8 | 0=None, 1=Currents12, 2=SinCos, 4=PWMOutput13, 8=PWMOutput23 |
Parameters Details
First Run (PWM verify)
Navigate to the Web Interface
Stop the inverter
DC-DC Converter
12v Battery Connection
Motor Connection
IDC Connector
Connections are as follows:
Pin Number | Label | Description |
1 | 12V_IN | Provide with +12V supply from battery or power supply for testing |
2 | 12V_IN | Provide with +12V supply from battery or power supply for testing |
3 | MG2_FORW_IN | Active high signal at 12V (switches at >7V) to tell the inverter which way to spin the motor. Take positive feed from 12V battery or supply and wire through a three position switch, with the switched connections running to forward and reverse. |
4 | MG2_REVER_IN | Active high signal at 12V (switches at >7V) to tell the inverter which way to spin the motor. Take positive feed from 12V battery or supply and wire through a three position switch, with the switched connections running to forward and reverse. |
5 | MG2_START | Active high signal at 12V (switches at >7V) to start the inverter and move it from pre-charge to run mode. Typically connected to the momentary 'START' position of your ignition switch. |
6 | MG2_BRAKE_ON | Active high signal at 12V (switches at >7V) to inform the inverter that the car is under braking. Typically takes a feed from the brake switch that also turns on brake lights etc. |
7 | CRUISE_IN | Active high signal at 12V (switches at >7V) to turn on cruise control mode. This sets the current motor speed as the set point for cruise control. Cruise control is disabled by a signal from the brake switch. |
8 | VCC_5V | +5V supply for temperature and throttle sensors |
9 | MG2_ACCEL | 5V analogue input from first channel of throttle sensor. These typically take a 5V supply and ground and return to this pin a variable voltage that indicates throttle position. |
10 | MG2_BRAKE_TRANS | 5V analogue input from second channel of throttle sensor. These typically take a 5V supply and ground and return to this pin a variable voltage that indicates throttle position. |
11 | GND | Common ground for 12V supply or 5V return. |
12 | GND | Common ground for 12V supply or 5V return |
13 | CAN_EXT_H | CANBus digital communication connection for remote interface with inverter |
14 | CAN_EXT_L | CANBus digital communication connection for remote interface with inverter |
15 | VCC_5V | +5V supply for temperature and throttle sensors |
16 | MG2_ENC_1 | Can be either digital input for encoder (in which case, connect the relevant encoder output here and provide the device with 5V and ground), or one of the two connections for the SIN winding if you are using a resolver for motor position. |
17 | MG2_ENC_2 | Can be either digital input for encoder (in which case, connect the relevant encoder output here and provide the device with 5V and ground), or one of the two connections for the COS winding if you are using a resolver for motor position. |
18 | GND | Common ground for 12V supply or 5V return |
19 | MG2_COSA | Connect SIN winding of motor resolver here and to Encoder Channel A |
20 | MG2_SINA | Connect COS winding of motor resolver here and to Encoder Channel B |
21 | MG2_EXCA | Connect exciter winding of motor resolver here and to ground |
22 | GND | Common ground for 12V supply or 5V return |
23 | MG2_STATOR_T1 | 5V analogue input from motor temperature sensor. These are typically variable resistance devices. Connect the other side of the sensor to +5V. |
24 | MG2_STATOR_T2 | 5V analogue input from motor temperature sensor. These are typically variable resistance devices. Connect the other side of the sensor to +5V. |
25 | MAIN_CON | Open Collector (Will switch the ground side from disconnected to ground).
26 | PRECHG_RLY | Open Collector (Will switch the ground side from disconnected to ground).
27 | AC_CON | Open Collector (Will switch the ground side from disconnected to ground).
28 | HV_CON | ? |
29 | AC_PRECH | Open Collector (Will switch the ground side from disconnected to ground).
30 | GND | Common ground for 12V supply or 5V return |
31 | EVSE_PROX | |
32 | CONTROL_PILOT | |
33 | CHG_CANH | CANBus digital communication connection for remote interface with charger |
34 | CHG_CANL | CANBus digital communication connection for remote interface with charger |
Ampseal Socket & Plug
Pin Number | AMPSeal Pinout Label | Description |
1 | 12V SUPPLY POSITIVE | Provide with +12V supply from battery or power supply for testing |
2 | GROUND | Common ground for 12V supply or 5V return |
3 | FORWARD DIRECTION SIGNAL | Active high signal at 12V (switches at >7V) to tell the inverter which way to spin the motor. Take positive feed from 12V battery or supply and wire through a three position switch, with the switched connections running to forward and reverse. |
4 | REVERSE DIRECTION SIGNAL | Active high signal at 12V (switches at >7V) to tell the inverter which way to spin the motor. Take positive feed from 12V battery or supply and wire through a three position switch, with the switched connections running to forward and reverse. |
5 | START SIGNAL | Active high signal at 12V (switches at >7V) to start the inverter and move it from pre-charge to run mode. Typically connected to the momentary 'START' position of your ignition switch. |
6 | BRAKE DIGITAL SIGNAL | Active high signal at 12V (switches at >7V) to inform the inverter that the car is under braking. Typically takes a feed from the brake switch that also turns on brake lights etc. |
7 | CRUISE CONTROL SIGNAL | Active high signal at 12V (switches at >7V) to turn on cruise control mode. This sets the current motor speed as the set point for cruise control. Cruise control is disabled by a signal from the brake switch. |
8 | 5V OUT | +5V supply for temperature and throttle sensors |
9 | ACCELERATOR CHAN 1 INPUT | 5V analogue input from first channel of throttle sensor. These typically take a 5V supply and ground and return to this pin a variable voltage that indicates throttle position. |
10 | ACCELERATOR CHAN 2 INPUT | 5V analogue input from second channel of throttle sensor. These typically take a 5V supply and ground and return to this pin a variable voltage that indicates throttle position. |
11 | GROUND | Common ground for 12V supply or 5V return. |
12 | INVERTER CAN HIGH | CANBus digital communication connection for remote interface with inverter |
13 | INVERTER CAN LOW | CANBus digital communication connection for remote interface with inverter |
14 | +5V OUT | +5V supply for temperature and throttle sensors |
15 | ENCODER CHAN A | Can be either digital input for encoder (in which case, connect the relevant encoder output here and provide the device with 5V and ground), or one of the two connections for the SIN winding if you are using a resolver for motor position. |
16 | ENCODER CHAN B | Can be either digital input for encoder (in which case, connect the relevant encoder output here and provide the device with 5V and ground), or one of the two connections for the COS winding if you are using a resolver for motor position. |
17 | GROUND | Common ground for 12V supply or 5V return |
18 | RESOLVER SIN | Connect SIN winding of motor resolver here and to Encoder Channel A |
19 | RESOLVER COS | Connect COS winding of motor resolver here and to Encoder Channel B |
20 | RESOLVER EXC | Connect exciter winding of motor resolver here and to ground |
21 | GROUND | Common ground for 12V supply or 5V return |
22 | MOTOR TEMP SENSOR A | 5V analogue input from motor temperature sensor. These are typically variable resistance devices. Connect the other side of the sensor to +5V. |
23 | MOTOR TEMP SENSOR B | 5V analogue input from motor temperature sensor. These are typically variable resistance devices. Connect the other side of the sensor to +5V. |
24 | MAIN HV CONTACTOR | Open Collector (Will switch the ground side from disconnected to ground).
25 | HV PRECHARGE RELAY | Open Collector (Will switch the ground side from disconnected to ground).
26 | CHARGER AC INPUT RELAY | Open Collector (Will switch the ground side from disconnected to ground).
27 | CHARGER HV DC REQUEST | |
28 | CHARGER AC PRECHARGE RELAY | Open Collector (Will switch the ground side from disconnected to ground).
29 | GROUND | Common ground for 12V supply or 5V return |
30 | EVSE PROXIMITY SIGNAL | |
31 | EVSE CONTROL PILOT SIGNAL | |
32 | CHARGER CAN HIGH | CANBus digital communication connection for remote interface with charger |
33 | CHARGER CAN LOW | CANBus digital communication connection for remote interface with charger |
34 | NOT USED | |
35 | NOT USED |
Connecting Resolver
Bill of Materials (Github)
