Using Zombie with Leaf Inverter
raisinscry
Post by raisinscry »
I'm running a Gen 2 Leaf motor and inverter setup, controlled by a Zombie. Does the Leaf inverter already measure current internally, or do I still need to add an IVT-S shunt?
GregFordyce
Has thanked: 8 times
Been thanked: 6 times
Re: Using Zombie with Leaf Inverter
Post by GregFordyce »
From firmware 2.20 you no longer need the IVT-S shunt.
Peugeot Expert LWB 2009
Zombieverter - Full 80kW Leaf stack
24kWh & 30kWh Leaf batteries in custom battery box under van
Has thanked: 209 times
Been thanked: 578 times
GregFordyce wrote: Mon Jul 07, 2025 6:33 am From firmware 2.20 you no longer need the IVT-S shunt.
Not correct.
raisinscry wrote: Mon Jul 07, 2025 2:04 am Does the Leaf inverter already measure current internally
It does not measure current, it only measures voltage, you do not need the IVT-s to do precharge. So you can run the leaf stack without an IVT-s but you would not be able to measure the current draw only the inverter input voltage.
Has thanked: 383 times
Been thanked: 1576 times
Maybe Greg was referring to Leaf BMS support?
