Using Zombie with Leaf Inverter
raisinscry
I'm running a Gen 2 Leaf motor and inverter setup, controlled by a Zombie. Does the Leaf inverter already measure current internally, or do I still need to add an IVT-S shunt?
- GregFordyce
- Has thanked: 43 times
- Been thanked: 29 times
Re: Using Zombie with Leaf Inverter
From firmware 2.20 you no longer need the IVT-S shunt.
Peugeot Expert LWB 2009
Zombieverter - Full Gen2 Leaf stack
24kWh & 30kWh Leaf batteries in custom battery box under van
- Has thanked: 330 times
- Been thanked: 848 times
Not correct.
It does not measure current, it only measures voltage, you do not need the IVT-s to do precharge. So you can run the leaf stack without an IVT-s but you would not be able to measure the current draw only the inverter input voltage.raisinscry wrote: ↑Mon Jul 07, 2025 2:04 am Does the Leaf inverter already measure current internally
- Been thanked: 1918 times
Maybe Greg was referring to Leaf BMS support?
- GregFordyce
Thanks for putting me straight, I'm still getting my head round the ZV.
I was confusing the Leaf BMS support with the inverter functionality.
