Using Zombie with Leaf Inverter
raisinscry
Post by raisinscry »
I'm running a Gen 2 Leaf motor and inverter setup, controlled by a Zombie. Does the Leaf inverter already measure current internally, or do I still need to add an IVT-S shunt?
GregFordyce
Has thanked: 43 times
Been thanked: 29 times
Re: Using Zombie with Leaf Inverter
Post by GregFordyce »
From firmware 2.20 you no longer need the IVT-S shunt.
Peugeot Expert LWB 2009
Zombieverter - Full Gen2 Leaf stack
24kWh & 30kWh Leaf batteries in custom battery box under van
Has thanked: 330 times
Been thanked: 848 times
GregFordyce wrote: Mon Jul 07, 2025 6:33 am From firmware 2.20 you no longer need the IVT-S shunt.
Not correct.
raisinscry wrote: Mon Jul 07, 2025 2:04 am Does the Leaf inverter already measure current internally
It does not measure current, it only measures voltage, you do not need the IVT-s to do precharge. So you can run the leaf stack without an IVT-s but you would not be able to measure the current draw only the inverter input voltage.
Maybe Greg was referring to Leaf BMS support?
GregFordyce
Thanks for putting me straight, I'm still getting my head round the ZV. 😬 I was confusing the Leaf BMS support with the inverter functionality.
