New BMS / ‘weak’ cell clarifications
So my correct* BMS arrived to match the 60kWh battery and to replace the 40kWh BMS I had been using. As expected, the predicted range and SOC charge makes more sense now. (The 40kWh BMS will be for sale if anyone’s looking)
I’ve just done a real world test drive to prove its range. 150 miles. This was on a warm day, about 80% driving at 50 - 60mph. Had an extra passenger for some of the drive and some extra weight on board from packages I was moving so pretty good test I think.
I drove it down to turtle mode, so I now have a real understanding of my limits.
*actually the BMS is from a 62kWh, whereas mine is 60. So there remains a minor disconnect. My original 60kWh BMS reported the battery as 165Ah. This new one thinks it’s 175Ah, so I think that means it would let me try to charge up to a greater capacity than my battery actually supports. So I will never test that, and will aim to manually stop based on Ahr rather than SOC %.
To prep for my extended drive I had stopped charging at 162Ah. The VCU reported this as 97%, LeafSpy thought 92.6%. Then ran down to 4% on VCU display. This would have been fine, if it wasn’t for my weak cell#55, which really was not happy at the very steep track we live up. It’s 18% / 1:5.4 gradient and I couldn’t make it to the top. Had to roll back down! That cell had dropped dramatically to 400mV below average under that load and I guess the BMS decided to intervene. It had been a little low before that, but nothing extreme.
Left the bus at the bottom, came back later and crawled slowly up the hill and made it back to the house. Cell #55 gradually recovered on its own with the delta reducing at a steady rate. Then once the battery was put on a slow charge, it rejoined the rest of the pack. I’ve since been on a couple of drives and there’s no lasting effect. But clearly going down to 4% is not a good thing to do - at least when/if I replace the module with cell #55 in it.
Then there’s cell #67 which was the discussion from the last few comments with T1Terry, Brat and Tom. I’d talked about an extra voltage peak during Chademo charging. As was pointed out, this is likely the BMS miscalculating because it is unable to accommodate the extra resistance from a 2m HV cable that the OEM battery didn’t have.
I wasnt sure before, but that same cell voltage does also drop under acceleration, which I think Tom suggested I’d expect to see. As soon as the load is removed, LeafSpy shows nothing unusual with this cell #67.
I wondered whether I’d find that as my SOC charge ran down that the drop on 67 under load might impact performance. But as far as I can tell that wasn’t the case. I was still accelerating to test performance with a low SOC and seemed normal. So that means I only have to be conscious of whether #55 is misbehaving.
Talking of load under acceleration, there is something. Bear in mind this vehicle is not intended as a race day winner! I’m happy with the improved acceleration compared to the previous 1800cc petrol lump, and being able to keep going all the way up to 60mph is pure joy
But if I forget myself and decide to try to jump off at the lights or a roundabout and demand too much, the power cuts out for a split second. This can happen when moving off from 0mph. Doesn’t happen once I’ve got momentum up. Not a problem I’m too concerned about, I just won’t be stupid and try to win races at the lights!
Sorry for the lengthy one
BTW - battery temp didn’t go above 31deg C.
Anyone got real world info on best practice for Leaf motor stack temperature?
