[DRIVING] Leaf to VW Type 2 Campervan
Re: [FIRST DRIVE] Leaf to VW Type 2 Campervan
This all looks very familiar and typical Leaf BMS ;)
"Flying Tools" and youtube runs 8 MEB modules with Leaf BMS and of course the SoC calculation is off. Leaf 40 kWh cells must be in the 110 Ah ball park while 60 kWh is more like 165 Ah. So SoC calculation is off by 2/3.
Same goes for the jumper wire. The BMS then measures cell voltage+voltage drop (or rise) over the wire.
ianlighting
Has thanked: 258 times
Been thanked: 189 times
Post by ianlighting »
johu wrote: Thu May 15, 2025 5:31 am This all looks very familiar and typical Leaf BMS ;)
Thanks.
When I started this I decided using OEM parts would be a good policy as it meant no configuration (at least using my Resolve-EV VCU). But when it comes the BMS I can see now that maybe being able to tweak the parameters of a BMS to better match the battery box(es) you actually build could be an advantage. If I did this again, I’d give that a bit more thought.
What is unknown to me with the parts I have is what effect a low SOC has on the system. If I went down to a reported ‘zero’ on remaining capacity, does actually mean I have 30% still in the battery? And will it enforce a safety turtle mode because it believes I’m close to empty.
ianlighting wrote: Thu May 15, 2025 6:02 am If I went down to a reported ‘zero’ on remaining capacity, does actually mean I have 30% still in the battery? And will it enforce a safety turtle mode because it believes I’m close to empty.
I haven't gone there, so I don't know if it drops the discharge limit based just on voltage or also supposed SoC. One trick you can pull is pull over, cycle 12V supply to BMS. Then it will estimate SoC based on voltage and you're back up.
The Leaf experts will know whether you can program SoH>100% or greater AH in the first place.
ianlighting
I promise not to document every time I go to a public charger, I realise that could be one of the most tedious travelogues ever. But worth sharing that at Winchester InstaVolt today, they wanted to take my photo and give me a free charge! Think I got lucky because there looked to be a management tour going on of their new 40 charger facility so the marketing dept were up for something more interesting than a Tesla.
Anyway, was happy to chat but declined for the moment. But took her email and promised to go back once I’d passed DVLA checks, so all nice and legal. If anyone else in an interesting EV conversion wants to come along I’ll try to co-ordinate. Not imminent, got a few things to do, but let me know.
Anyway, back to business. Did 25 miles to Instavolt’s Chademo charger. Charged up to 75%, drove 80 miles, and parked up at home after lots of 50 - 60 mph driving with 9% / 10Ah remaining
On that basis, it would be 118 miles range with zero left.
But this is with my 40kWh BMS on a 60kWh battery. If (still to be confirmed I think) I could expect 30% more if it was a 60kWh BMS the range would be 150 miles. That’s more what I was hoping for.
The final LeafSpy (it’s zoomed in below, so looks worse than it is) once back home shows 3.60 for the lowest cell and 347V for the pack. I think I’m right in saying that I’d expect to see the low cells much lower than that on a close to empty battery. So gives me hope that my range can go closer to the 150 than 100. But whether that is possible with the current BMS is something I haven’t dared to push yet.
I know there are Leaf BMS reflashing efforts ongoing in another forum. But if I was confident a CANBridge might do the job, I’d probably be happy to go for that to avoid the risk of clumsy me bricking the BMS.
Go on, admit it, you do really want to see me parked at another charger :)
ianlighting
So CANbridge isn’t the answer. Investigating 62kWh BMS.
In other news, cable tidying…
1) Engine Bay now much nicer… (aaargh, upside down!)
2) VCU wiring up at the front. Getting there, still a bit to do on the driver controls part which are still a bit temporary.
T1Terry
Has thanked: 24 times
Been thanked: 27 times
Post by T1Terry »
ianlighting wrote: Mon May 12, 2025 4:45 pm IMG_8468.jpeg
Decided for my next test that if I was going to burn somewhere down with a battery fire I’d rather do the Shell garage than the local hotel (dear lawyers, this is just a poor taste joke and not a statement of intent).
All went ok.
I’ve moved on from focussing on my weak cell 55 as he doesn’t seem to be much of a problem. Still a slacker, but nothing serious.
All the attention now is cell 67. As mentioned this is the first cell of module 11 on a 2meter HV extension and the first of 30 cell tap extensions.
Just to be sure, Ive remade the BMS connections to all the cells in module 11. Rechecked the HV for a tight connection and retested around the block and then on to the Shell.
So this is what I get to watch when Chademo charging. Playing chicken with battery cell!
That 99mV can bounce around of course, think up to 150 at one point.
I called it quits at 85% SOC and with cell 67 reaching about 4.08. That’s an upper limit I’m happy with. I’d prefer not to experiment with that cell hitting 4.10 and higher, although happy to hear anyone’s thoughts on safe voltages for a leaf 60kWh battery cell.
Edit - this is only a rapid charging problem as far as I know so far. Should I have the need, I ought to be able to go higher on my home 2kW charging.
Battery temp got up to 26.5deg
Chademo charging started at 30-something kW, but then was down in the 20s. Did about 30minutes.
Once I was done charging cell 67 rejoins the rest of the pack. Then 15 min drive home and final LeafSpy when at rest.
Is the voltage on that high cell being measured at the cell or at the end of a series link joining the last module to the module with the high voltage when charging? In other words, measuring between cell 67 @4.065v and cells 68 and 69 that are both low at around 3.985v. The cell average voltage at that point was 3.99v.
I'm thinking the high reading is being exaggerated because of additional resistance between the negative on the high cell and the negative on the next cell that is using to get used to get voltage reading across cell 67 and this affecting the voltage reading of cell 68 and 69 ......
This can generally be verified if the voltage drops on the high cell when the charging stops, yet rises on the next two cells, then drops even more if a load is applied and the next two cells rise further ......
Not sure if any of that made sense, it did in my head when I was writing it, but not so sure reading back after posting it :?
T1 Terry
Taking on more projects than I have yrs left in me, but, not dead yet, so far, so good :D
ianlighting
T1Terry wrote: Mon May 19, 2025 9:40 am Is the voltage on that high cell being measured at the cell or at the end of a series link joining the last module to the module with the high voltage when charging? In other words, measuring between cell 67 @4.065v and cells 68 and 69 that are both low at around 3.985v. The cell average voltage at that point was 3.99v.
T1 Terry
The main conclusion I reached is that there isn’t much I can do about it apart from monitor it to make sure it doesn’t peak too high.
Since that post, I’ve done another drive of 80 miles, often at 60 mph. And done an AC charge from a low SOC back up to 90%. None of this causes that situation. It’s only a Chademo charge that will stress things and display those peaks on each module, with that module 11 being the worst. As long as I know the potential risk area, that’s the main thing. There’s nothing I can do about the HV or cell tap cable lengths, and I’ve remade the module 11 connections to be absolutely sure. I can set a max charge limit to 85% which should keep it within safe limits based on what I’ve seen so far. Most of the time that’s going to be plenty to get back from wherever I’ve been.
I’m not testing Chademo again until I have my 60kWh BMS (in the post), since the way results are displayed on LeafSpy should adjust a little, so that will need to be how I benchmark behaviour for the future.
Has thanked: 246 times
Been thanked: 469 times
ianlighting wrote: Tue May 20, 2025 5:56 am The main conclusion I reached is that there isn’t much I can do about it apart from monitor it to make sure it doesn’t peak too high.
His statement is if the measurement it self is in correct, not that the cell it self is too high
ianlighting
Bratitude wrote: Thu May 22, 2025 12:57 pm
His point is interesting. But there is no way to verify since it’s the BMS that reports this data and it’s only seen during a fast Chademo charge.
Even if the BMS is not reporting accurate voltage due to the wiring changes I’ve done compared to OEM original, I still have to behave as though they are ‘real’. Because any safety measures the BMS might take to protect a cell, module or pack, due to a cell that has overly high voltage, are going to be real. I’m speculating on the BMS behaviour, but if the BMS decided to shut down to prevent a cell reaching too high a voltage for example, it doesn’t matter if the cell is actually at a normal level if it was tested separately. All that matters is what the BMS thinks.
So that means charging up to 100% on AC (only tested up to 90% so far) is fine, and 85% on Chademo, keeps cell 67 within a safety margin.
It’s a bonus if cell 67 is actually not peaking in the way the BMS reports.
If the bms is not reading correctly, going to do the incorrect function. A safe response is predicated on if the data collected is data that accurately represents the real world. If that model is wrong… it’s not “safe”
What the bms reads and what the cells actually read might be different… you’re going to need to verify that…..in which u can. You just need to have an external meter on those cells and run a test. If the numbers are the same between your meter and bms then it’s good to go
ianlighting
Bratitude wrote: Thu May 22, 2025 4:37 pm If the bms is not reading correctly, going to do the incorrect function. A safe response is predicated on if the data collected is data that accurately represents the real world. If that model is wrong… it’s not “safe”
I do agree that accurate data in = valid response out.
But I also have to deal with the real world and make a judgement on what I consider to be high risk. Breaking into the HV cell taps in a such a way that fast charging can carry on, but also extending wires to allow a multimeter to read the live charging voltage introduces risk. That might be ok at home. But doing this in a public charging place with people wandering around, I’m not comfortable with that. Too much potential for distraction or mistakes.
I will get back to Chademo testing when the 62kWh BMS arrives - just been delayed a week. So I can think again based on results I see with what I hope will be the final, long term BMS. If I think it’s worth the risk at that point I can do as you suggest.
Has thanked: 330 times
Been thanked: 847 times
Have you figured out where the offending cell is?
Does it also sag under heavy loads? If so it could be an extended cable.
ianlighting
tom91 wrote: Fri May 23, 2025 7:52 am Have you figured out where the offending cell is?
Yes, I know where it is. And yes it is at the start of a module on an extended main HV cable. I’m sure that’s the reason.
It also has extended cell tap wires, but then so do 29 other cells. So the unique thing is the main HV.
Under AC charging it’s fine. Not noticeable during driving.
I haven’t noticed a drop under heavy acceleration, but I probably need to repeat tests with particular focus on that next.
So yea the HV cable will be the change. As you are measuring including volt drop (during discharge) and volt increase during charging.
Specially since during charging its a steady current for a while so it will be picked up better by the BMS.
ianlighting
tom91 wrote: Fri May 23, 2025 8:19 am So yea the HV cable will be the change. As you are measuring including volt drop (during discharge) and volt increase during charging.
Unless an expert specially called out what I was doing as particularly dangerous, i am not planning to change the setup, just monitor and manage it.
But I am interested to understand how non-OEM BMSs deal with this scenario. Do they let you configure cable size and resistance so that cell tap monitoring and balancing takes this into account? On a cell by cell basis?
It is not dangerous, as long as the connections are fine, you can just throw faults/derate more quickly.
ianlighting wrote: Fri May 23, 2025 8:28 am Do they let you configure cable size and resistance so that cell tap monitoring and balancing takes this into account? On a cell by cell basis?
Yes a lot feature "busbar compensation"
ianlighting
New BMS / ‘weak’ cell clarifications
So my correct* BMS arrived to match the 60kWh battery and to replace the 40kWh BMS I had been using. As expected, the predicted range and SOC charge makes more sense now. (The 40kWh BMS will be for sale if anyone’s looking)
I’ve just done a real world test drive to prove its range. 150 miles. This was on a warm day, about 80% driving at 50 - 60mph. Had an extra passenger for some of the drive and some extra weight on board from packages I was moving so pretty good test I think.
I drove it down to turtle mode, so I now have a real understanding of my limits.
*actually the BMS is from a 62kWh, whereas mine is 60. So there remains a minor disconnect. My original 60kWh BMS reported the battery as 165Ah. This new one thinks it’s 175Ah, so I think that means it would let me try to charge up to a greater capacity than my battery actually supports. So I will never test that, and will aim to manually stop based on Ahr rather than SOC %.
To prep for my extended drive I had stopped charging at 162Ah. The VCU reported this as 97%, LeafSpy thought 92.6%. Then ran down to 4% on VCU display. This would have been fine, if it wasn’t for my weak cell#55, which really was not happy at the very steep track we live up. It’s 18% / 1:5.4 gradient and I couldn’t make it to the top. Had to roll back down! That cell had dropped dramatically to 400mV below average under that load and I guess the BMS decided to intervene. It had been a little low before that, but nothing extreme.
Left the bus at the bottom, came back later and crawled slowly up the hill and made it back to the house. Cell #55 gradually recovered on its own with the delta reducing at a steady rate. Then once the battery was put on a slow charge, it rejoined the rest of the pack. I’ve since been on a couple of drives and there’s no lasting effect. But clearly going down to 4% is not a good thing to do - at least when/if I replace the module with cell #55 in it.
Then there’s cell #67 which was the discussion from the last few comments with T1Terry, Brat and Tom. I’d talked about an extra voltage peak during Chademo charging. As was pointed out, this is likely the BMS miscalculating because it is unable to accommodate the extra resistance from a 2m HV cable that the OEM battery didn’t have.
I wasnt sure before, but that same cell voltage does also drop under acceleration, which I think Tom suggested I’d expect to see. As soon as the load is removed, LeafSpy shows nothing unusual with this cell #67.
I wondered whether I’d find that as my SOC charge ran down that the drop on 67 under load might impact performance. But as far as I can tell that wasn’t the case. I was still accelerating to test performance with a low SOC and seemed normal. So that means I only have to be conscious of whether #55 is misbehaving.
Talking of load under acceleration, there is something. Bear in mind this vehicle is not intended as a race day winner! I’m happy with the improved acceleration compared to the previous 1800cc petrol lump, and being able to keep going all the way up to 60mph is pure joy :)
But if I forget myself and decide to try to jump off at the lights or a roundabout and demand too much, the power cuts out for a split second. This can happen when moving off from 0mph. Doesn’t happen once I’ve got momentum up. Not a problem I’m too concerned about, I just won’t be stupid and try to win races at the lights!
Sorry for the lengthy one :)
BTW - battery temp didn’t go above 31deg C.
Anyone got real world info on best practice for Leaf motor stack temperature?
ianlighting
Just done the DVLA process which I’ve documented in a thread about that topic here…
viewtopic.php?p=84252#p84252
I’ve been told verbally it’s passed, so good news.
…and means I can update my project status to DRIVING, whoop! Although I’m going to wait for the paperwork to land before I do that, just in case…
WillK
Has thanked: 65 times
Been thanked: 8 times
Post by WillK »
Congratulations, that's a huge step & must be a big relief.
Really appreciated how you've documented your build. Will be invaluable when I start my T2 conversion next year...
Thanks!
ianlighting
WillK wrote: Wed Jul 09, 2025 6:25 pm Congratulations, that's a huge step & must be a big relief.
Thanks!
Thanks! It’s nice to think it can be useful to someone else, considering I don’t have a very deep knowledge about this stuff yet. I remain in awe of all the expert mechanical engineering and coding skills I read about elsewhere in these pages.
BTW, another one for you in case you’ve not seen it - Fix It Scotty, on YouTube. It’s another bay window, and he does go into some good detail even though the EV build is quite different to mine. He has 2 parallel playlists, the EV conversion, and the bus resto.
ianlighting
Thanks!
Sorry had my wires crossed for a second and thought you were Jerrykco replying.
Where are you based Willk? Looking forward to seeing your build page :)
WillK
Post by WillK »
No problems.
'72 bay window here so following yours & Cera's builds closely.
I'm currently based between Lancashire (work) and Gloucestershire (home & camper).
Will retire to Glos next year, which will give me the time to do conversion. - will def. have a build thread.
Had our bay just over 10 years - did a full refurb then, and have had loads of great holidays - currently in Brittany for it's last main petrol-powered adventure. Can't wait to get started in converting..
Hope you get a trip away in yours soon!
ianlighting
WillK wrote: Wed Jul 09, 2025 7:15 pm No problems.
Well Gloucestershire isn’t too far away from Newbury where I am, so if it helps to meet up in person when the time is right, give me a shout.
And yes, music fest beckons in 2 days time!
ianlighting
We’re gonna need a bigger… radiator.
Up til now the motor temperature in my conversion reported by LeafSpy hasnt gone over 70deg C. In a not very scientific comparison test, a few weeks ago I drove our standard issue Nissan Leaf for 30 minutes down the motorway at 70mph to see what ‘normal’ should look like, and got a similar temperature.
On Friday, with outside temperatures of 31 C, and after driving 70 miles, the motor temperature hit 80C in the VW!
If anyone knows the upper limit for Leaf motor stack temperature, it would be good to hear. I knew the rad I used was a dinky little thing, but perhaps it’s not able to do a good enough job for the hotter days. Or maybe I’m still within acceptable limits? I’m a bit in the dark on this one.
But in good news, the prime directive of getting to and from music festivals has been achieved. Drove 140 miles there and back, so did it on a single charge with 15% usable battery capacity remaining. Loaded up with 1 wife, food, drink, chairs, table and assorted paraphernalia :)
Romale
Has thanked: 346 times
Been thanked: 101 times
Post by Romale »
this temperature is quite normal, there is no need to worry.
for the inverter, anything above 80° is critical, and the motor can tolerate 130° in long climbs.
evil neodymium :twisted:
