I've now got CCS charging with FOCCCI on the BMW (
viewtopic.php?p=78345#p78345) but it uses the max charge rate from the BMS, which is pretty slow as the Kangoo ZE never had rapid charging.
As you can see at: 11% SoC the max charge rate is 63A battery was at 14 degrees C.
So I put it on charge (3kW) and took a look at the derating:
11% -> 63A
60% -> 20A
69% -> 15A
83% -> 10A
Batteries at min: 12oC max: 15oC
I'm thinking I want to implement my own offset to raise this, based on temperature, so maybe if min cell over 10 and max cell under 30 and charge limit > 10 then either 2 or 2.5 multiplier.
What's peoples thoughts on this? Should temperature have some affect on the multiplier?
