[Driving] BMW E91 320d 2006
Woodfie
Has thanked: 221 times
Been thanked: 95 times
Re: [Driving] BMW E91 320d 2006
Post by Woodfie »
Bigpie wrote: Mon Jul 08, 2024 9:38 am
We're 120 miles in now, all going great.
Been reviewing your 5 minute drive with interest, acceleration is impressive, tyres will likely be a higher running cost than home charging .🙄
The HMT you mention, I take it you mean from the vcu to the inverter, does it restart by itself ?
I see you have just posted a trans/motor change, here am referring ti your 20th July.
Has thanked: 83 times
Been thanked: 429 times
inverter to VCU drops out for some reason, intermittently, it begins receiving again.
Has thanked: 382 times
Been thanked: 1574 times
Found this. Go a few minutes in :)
I keep forgetting to watch it. Hopefully the host will be signing up here soon, he's looking to convert a MG TF?
janosch
Has thanked: 98 times
Been thanked: 102 times
Post by janosch »
I had the pleasure of taking a close look at Jamies BMW over Christmas.
Excellent build, highlights from the short visit:
  • own telemetry app to OEM standard
  • swift pull-away from a stop
  • electrical power-steering without any noise
  • Is Jamie the first person in the world to rapid charge Renault Kangoo batteries?
So cool! Merry Christmas.
I've now got CCS charging with FOCCCI on the BMW (viewtopic.php?p=78345#p78345) but it uses the max charge rate from the BMS, which is pretty slow as the Kangoo ZE never had rapid charging.
As you can see at: 11% SoC the max charge rate is 63A battery was at 14 degrees C.
So I put it on charge (3kW) and took a look at the derating:
11% -> 63A
60% -> 20A
69% -> 15A
83% -> 10A
Batteries at min: 12oC max: 15oC
I'm thinking I want to implement my own offset to raise this, based on temperature, so maybe if min cell over 10 and max cell under 30 and charge limit > 10 then either 2 or 2.5 multiplier.
What's peoples thoughts on this? Should temperature have some affect on the multiplier?
Yes it should. All OEMs derate at low and high temp. I tried to replicate what VW does:
https://github.com/jsphuebner/stm32-car ... mebbms.cpp
Yes, I was thinking of sticking to the BMS limits outside of a specific temperature range. Within 10 to 30 degrees just multiply by 2.5 the BMS given limit.
Or.do you think that I should also modify the multiplier within this range also, based on temperature?
modellfan
Has thanked: 17 times
Been thanked: 18 times
Post by modellfan »
janosch wrote: Fri Dec 27, 2024 12:16 pm [*]own telemetry app to OEM standard
Any more detailed information on this? I am highly intrested.
That's not 100% correct, I've written a ZombieVerter module for OVMS. Not fully finished yet, but I can monitor the car over the cellular connection and see it's position. I'm working on preheating at the moment.
https://docs.openvehicles.com/en/latest ... index.html
janosch
Post by janosch »
You know what, I stand by what I said. Sure, you combined the ZombieVerter output with the OVMS app and added your own module code. But the result is still your telemetry app, that doesn’t need to fear Tesla’s!
When I layer onions, minced meat, and pasta sheets for baking, I call it my lasagna - even if I didn’t grow the onions myself.
Mihai
Post by Mihai »
Hey,
I just watched your whole series on youtube yesterday. Congratulations on an awesome build. Your reactions to accelerating, in the first road test episode, were priceless. And from what I gathered you’ve contained the conversion to under the hood, leaving you with a whole functional estate car, which I bet is very useful with kids.
Awesome and inspiring. Thanks for taking the time to upload videos.
Everything is under the bonnet so the whole passenger compartment is untouched, which was one of the main goals of the project, along with ~100 miles range. Heating and AC (not there yet)
Mihai
Post by Mihai »
Bigpie wrote: Thu Mar 13, 2025 3:43 pm Everything is under the bonnet so the whole passenger compartment is untouched, which was one of the main goals of the project, along with ~100 miles range. Heating and AC (not there yet)
Very nice. Will you be video documenting the heating and AC part too, when you get to them? It would be very interesting to see how you will integrate them.
There's nothing on can bus for heating that I can find. For the moment Ive used the can mapping of zombie to map the AC button to control the heater.
Will need something else if/when I get to AC and want my button back.
So, the first year is almost over and renewal time for the insurance, looks likes it's going to be £1000 again.
Over last few days I've been tackling the rust on one of the rear arches.
Thankfully it was just surface rust.
Not perfect, but a lot better.
Next I'm working on mounting the AC compressor...
Has thanked: 418 times
Been thanked: 121 times
Post by Jacobsmess »
Looks good enough to me!
barracuda816
Has thanked: 45 times
Been thanked: 23 times
Post by barracuda816 »
Bigpie wrote: Tue Jun 03, 2025 12:22 pm So, the first year is almost over and renewal time for the insurance, looks likes it's going to be £1000 again.
Oof, Why So much? The fact that it's converted? Did you have it insured before the conversion?
I didn't, but since the conversion there's only one company that will insure me. I'm almost 40, clean licence, insured since 18 and no accidents or claims, ever.
Beetle conversion was 500 insurance, and previous ICE have always been around 400-500
So a small road trip to visit a friendly mechanic 130 miles away and I now have AC.
Still got a few things to do to tidy it up and integrate into the BMW controls. I've also put on a pretty weedy fan, so I need something with a bit more umph.
Give us V2L! 😄
Proton
Has thanked: 188 times
Been thanked: 48 times
Post by Proton »
Bigpie wrote: Sat Jul 05, 2025 5:22 pm So a small road trip to visit a friendly mechanic 130 miles away and I now have AC.
Make a video with the AC Implementation. I need to do that too but not sure yet which rute to take.
Ive taken a load of video, need to badly edit it together and upload
Bigpie wrote: Sat Jul 05, 2025 7:49 pm need to badly edit it together
Ever the perfectionist.
